Shooting Yourself in the Foot
Postby crustyasp46 » Mon Mar 26, 2012 5:22 pm
Shooting Yourself in the Foot - Languages Version
The proliferation of modern programming languages (all of which seem to have stolen countless features from each other) sometimes makes it difficult to remember what language you're currently using. This guide is offered as a public service to help programmers who find themselves in such a dilemma.
C: You shoot yourself in the foot.
C++: You accidentally create a dozen instances of yourself and shoot them all in the foot. Providing emergency assistance is impossible since you can't tell which are bitwise copies and which are just pointing at others and saying, "That's me, over there."
Fortran: You shoot yourself in each toe, iteratively, until you run out of toes, then you read in the next foot and repeat. If you run out of bullets, you continue anyway because you have no exception-handling ability.
Modula-2: After realizing that you can't accomplish anything in this language, you shoot yourself in the head.
COBOL: USEing a COLT 45 HANDGUN, AIM gun at LEG.FOOT, THEN place ARM.HAND.FINGER on HANDGUN.TRIGGER and SQUEEZE, THEN return HANDGUN to HOLSTER. CHECK whether shoelace needs to be retied.
LISP: You shoot yourself in the appendage which holds the gun with which you shoot yourself in the appendage which holds the gun with which you shoot yourself in the appendage which holds the gun with which you shoot yourself in the appendage which holds the gun with which you shoot yourself in the appendage which holds ...
BASIC: Shoot yourself in foot with water pistol. On big systems, continue until entire lower body is waterlogged.
FORTH: Foot in yourself shoot.
APL: You shoot yourself in the foot, then spend all day figuring out how to do in fewer characters.
APL: You hear a loud noise and a hole appears suddenly in your foot, but you are unable to figure out what happened.
Pascal: The compiler won't let you shoot yourself in the foot.
SNOBOL: If you succeed, shoot yourself in the left foot. If you fail, shoot yourself in the right foot.
Concurrent Euclid: You shoot yourself in somebody else's foot.
HyperTalk: Put the first bullet of the gun into the left of leg of you. Answer the result.
Motif: You spend days writing a a UIL description of you foot, the trajectory, the bullet, and the intricate scrollwork on the ivory handles of the gun. When you finally get around to pulling the trigger, the gun jams.
Unix: % Is foot.c foot.h foot.o toe.c toe.o % rm *.o rm: .o: No such file or directory % is %
Mathematica: You try to shoot yourself in the foot and then have to figure out why it didn't work.
Macsyma: You shoot yourself in the foot, but the hole appears in your head. You spend the rest of the day trying variations on option variables, until you stumble upon SHOOTFOOTMODE:True$ and SHOOTFOOTMODEWHICH:RIGHT$ ... Which are of course documented, but you couldnt find it until you knew the answer.
Maple:A ShootFoot function was not implemented in Release n, but will be included in Release n+1. Meanwhile, you may purchase Release n at the Release n+1 price (multiply the Release n price by 2.2, or by 3.7 outside North America.)
XBase: Shooting yourself is no problem. If you want to shoot yourself in the foot, you'll have to use Clipper.
Paradox: Not only can you shoot yourself in the foot, your users can too.
Revelation: You'll be able to shoot yourself in the foot, just as soon as you figure out what all these bullets are for.
Visual Basic: You'll shoot yourself in the foot, but you'll have so much fun doing it that you don't care.
Prolog: You tell your program you want to be shot in the foot. The program figures out how to do it, but the syntax doesn't allow it to explain.
370 JCL: You send your foot down to MIS with a 4000-page document explaining how you want it to be shot. Three years later, your foot comes back deep-fried.
Anonymous
Shooting Yourself in the Foot - OS Version
This was inspired by the recent file making its rounds on the Net describing how to shoot yourself in the foot in a variety of programming languages. Now, the madness is extended to operating systems.
Unix: You shoot yourself in the foot.
DOS: You keep running up against the one-bullet barrier.
MS-Windows: The gun blows up in your hand.
Windows NT: The gun is so huge and unwieldy that you have to keep swapping it from one hand to the other.
OS/2: The gun and the bullet aren't speaking to each other any more.
Mac Finder: It's easy to shoot yourself in the foot -- just point and shoot.
AIX: You can shoot yourself in the foot with either a .38 or a .45.
IRIX: The Terminator shoots you in the foot. A T-Rex bites your other foot.
SVR4: The gun isn't compatible with your foot.
Minix: You learn how to shoot yourself in the foot with a Saturday Night Special.
Linux: Generous programmers from around the world all join forces to help you shoot yourself in the foot for free.
HURD: You'll be able to shoot yourself in the foot Real Soon Now.
VM/CMS: IBM shoots you in the foot.
VMS: \FOOT\ ambiguous: supply more toes.
AMIGA-DOS: The gun works pretty well, except that few people use one and it's impossible to find bullets.
Mach: The bullets work pretty well, but they don't make guns for it any more.
Cray: You shoot yourself in the foot with an Uzi.
MasPar: You shoot all of your friends' feet simultaneously.
Anonymous
Re: Shooting Yourself in the Foot
Postby JAHGoVeg » Fri Mar 30, 2012 11:10 pm
I enjoyed that. (:
Users browsing this forum: No registered users and 30 guests
