Mame help
Mame help
Postby Rever111 » Thu Nov 29, 2018 3:25 am
Please I am brand new here. I want to set up a x arcade tank stick with retro games. It says it needs to use mame emulator. I see where you can donate to be an unlimited member. And I have no problem doing that , just want to make sure i get the right downloads. Again please help, .
Thank you
Rever111
Steam ID: http://steamcommunity.com/id/
http://steamcommunity.com/id/" target="_new"> http://steamcommunity.com/id/.png" border=0 width=160 height=45>
Re: Mame help
Postby Hot Trout » Thu Nov 29, 2018 10:59 am
Hi and welcome. Can you give me a link to the device you are going to use. Most likely it will want a smaller complete set of roms like the 0.37b11 MAME set or the 0.72 MAME set.
Both these sets and others are available in the single download packs which makes it easier.
Re: Mame help
Postby Rever111 » Thu Nov 29, 2018 11:57 am
https://support.xgaming.com/support/solutions/articles/12000003052-configuring-mame-for-x-arcade-use-the-easy-way
Rever111
Re: Mame help
Postby Hot Trout » Thu Nov 29, 2018 12:32 pm
If you are planning on using a Raspberry Pi for the emulator then you will need the 0.72 set. Let me know excatly what you intend to build hardware and OS wise and I will help with the correct set.
Re: Mame help
Postby Rever111 » Thu Nov 29, 2018 4:40 pm
I haven't purchased a system to run it yet. Do you have a suggestion? I was thinking windows or not sure if chrome OS would work?
Rever111
Re: Mame help
Postby Hot Trout » Thu Nov 29, 2018 6:07 pm
Rever111 wrote:I haven't purchased a system to run it yet. Do you have a suggestion? I was thinking windows or not sure if chrome OS would work?
It depends on what you are going to do. Using your PC is the easiest way and the most flexible. If you want to make it portable you could use a laptop or a Raspberry Pi. There are loads of options, it really depends.
Re: Mame help
Postby Rever111 » Fri Nov 30, 2018 1:20 am
I want to use windows. So I guess I will let you know when I buy something. I'm thinking windows xp. But I'll let you know when I get it. I appreciate your help me much. Thank you so much hot trout
Rever111
Users browsing this forum: No registered users and 88 guests
