emulation on a psp
emulation on a psp
Postby nightshade » Sat Nov 19, 2016 8:30 pm
Ok I can get a psp used for 10 bucks ...... aand I'm told you can run emus on it ............any site or place that explains how and whats the best emus to run on it? thanks..............
"theres no point it telling me the wisdom of a fool cant and wont set me free"-new order
"its always easier and usually better to get forgiveness than permission"-various
nightshade
Next LVL Up at : 170
Has thanked: 19 times
Been thanked: 57 times
Fav System: all systems
Re: emulation on a psp
Postby PMJPlay » Sun Nov 20, 2016 7:04 am
The first thing you probably need to do install custom firmware before you are able to put any emulators on it.
http://wololo.net/cfw4dummies
Postby Kherr » Fri Jun 16, 2017 5:07 pm
Actually, I've hacked 3 separate PSP systems in the past year or two. I can definitely throw up the required files to make it work for you, if you haven't figured it out by now. Sorry for the super lengthy delay. Let me know if you still need assistance. :)
Postby hack3rman72 » Thu Jul 13, 2017 5:43 pm
You also need to know what official firmware you're running. That way you know what custom firmware you can install. Or just install the latest OFW, and then install the latest CFW that works with the newest OFW.
END OF LINE
hack3rman72
Been thanked: 7 times
Postby nightshade » Thu Sep 14, 2017 7:20 am
thanks and I never bought one because all of a sudden the psps they couldn't give away a year or two ago is going for 75 bucks and up ....... due to everyone getting the same idea I did ......but ill keep it in mind should I find one
what about the vita? are they cracked yet?
nightshade
Postby Dragon Mech » Sun Sep 17, 2017 5:21 am
according to an August 08 article at Cheatcc.com (i'll post the url at the end of this post), a hacker group called Team Molecule cracked the vita and developed a program to permanently jailbrake the vita. and vita fans are now doing the same stuff for the vita as they did for the PSP.
here is the URL for the Cheatcc.com article.
http://dispatches.cheatcc.com/3126
Users browsing this forum: No registered users and 81 guests
