registered, unlimited user looking for all mame (.375b)
Postby scottnath » Thu Apr 23, 2015 4:09 am
Hi everybody!
I'm looking for the full, single download for all mames (Mame-0.37b5) but I can't seem to find the full link. Could someone please point me to where I could find a single download for all the mames?
I am a signed-in, unlimited user.
thank you,
Scott
scottnath
Re: registered, unlimited user looking for all mame (.375b)
Postby Hot Trout » Thu Apr 23, 2015 9:25 am
Welcome. Go to this folder under any section, in this case under the MAME section;
http://www.theoldcomputer.com/roms/inde ... Mega-Packs
ALL single download rom packs are stored here. You will need to download every part of the 7z archive (in your case all three files) to the same folder on your computer before you start to open the archive.
I hope this helps.
Postby spizza99 » Fri Aug 28, 2015 5:22 pm
Hi , I also have downloaded the 3 files but upon downloading them it adds .001 .002 and .003 to the files??? once downloaded i cannot unzip them or anything? can you advise the correct procedure please, thank you..
spizza99
Fav System: GCW
Postby Hot Trout » Tue Sep 01, 2015 1:43 pm
Download all the parts into the same folder, then use 7zip and click on the first part, this will then unzip all of the parts.
Postby spizza99 » Mon Sep 07, 2015 3:20 pm
thank you :-)
spizza99
Fav System: GCW
Users browsing this forum: No registered users and 82 guests
