The "LOGIN"
The "LOGIN"
Postby Flying Nosehair » Tue Sep 11, 2012 2:23 am
The "LOGIN" feature for the main website seems to be broken. It just links to "javascript:void();"
Flying Nosehair
Re: The "LOGIN"
Postby crustyasp46 » Tue Sep 11, 2012 5:35 am
Flying Nosehair wrote:The "LOGIN" feature for the main website seems to be broken. It just links to "javascript:void();"
Just did a login on the main website as registered and unregistered user ahd everything worked for me, the only thing I can suggest is do a refresh and try again, failing that try a different browser if you are able to.
Re: The "LOGIN"
Postby Hot Trout » Tue Sep 11, 2012 12:05 pm
I just checked it in chrome and ie9 and it worked for me ok.
Re: The "LOGIN"
Postby Flying Nosehair » Thu Sep 13, 2012 7:00 pm
I've tried logging in with FIrefox, and it worked. I'll just have to use that instead of Chrome.
Flying Nosehair
Re: The "LOGIN"
Postby harrybro » Thu Sep 27, 2012 6:36 am
Login with fire fox in any site is so secure than the others
harrybro
harrybro
Fav System: computer
Users browsing this forum: No registered users and 104 guests
