How do I block porn completely on my computer?
Re: How do I block porn completely on my computer?
Postby stinow » Mon Nov 21, 2011 11:25 am
Claire Green wrote:Is there a way that no porn is ever accessible on my computer. Like there is absolutely no way to access it? Or a password or something to block all porn?
Hi, in what way? So nobody on the computer can watch porn on:
* the Internet?
* local that is stored on the computer?
And does it have to count for all users? Or just specific ones?
Best regards,
Stijn
Postby Hot Trout » Mon Nov 21, 2011 5:55 pm
Hide the power lead.
Postby Alpensopath » Tue Dec 06, 2011 8:45 pm
This action will require you to edit your Host file. Your host file is a computer file used to store information on where to find a node on a computer network. For more a more detailed description. Check out this link Host File Description Link
In Windows XP
1. Click Start->All Programs->Accessories->Command Prompt.
2. Click Command Prompt This will open a DOS command window.
3. Type: notepad C:/Windows/System32/drivers/etc/hosts
4. Locate the line 127.0.0.1 localhost
5. To block the website google.com for example, just add this text under 127.0.0.1 localhost:
127.0.0.1 google.com
127.0.0.1 www.google.com
You can add as many sites any site, However you will need to prefix it with "127.0.0.1".
6. Save the file
Google will now be blocked in all web browser. This is an advanced but easy method on how to blow a website.
View more at: http://www.techyv.com/questions/i-want- ... y-computer
Alpensopath
Fav System: console
Users browsing this forum: No registered users and 85 guests
