HELP!! What is the best product for cooling a RAM?
Postby hang19840324 » Fri Aug 19, 2011 7:21 pm
Hey guys, I’ve got a problem with using my RAM … I used the thermal tape to attach my heatsink on it yet it’s still very hot. Sigh … seems like my cooler doesn’t cool down the RAM properly. My card was almost ruined when I tried to remove the heatsink. Please help !!! Is there something like a thermal pad that can resolve this problem?
hang19840324
Re: HELP!! What is the best product for cooling a RAM?
Postby crustyasp46 » Fri Aug 19, 2011 9:22 pm
hang19840324 wrote:Hey guys, I’ve got a problem with using my RAM … I used the thermal tape to attach my heatsink on it yet it’s still very hot. Sigh … seems like my cooler doesn’t cool down the RAM properly. My card was almost ruined when I tried to remove the heatsink. Please help !!! Is there something like a thermal pad that can resolve this problem?
This is a commercial site, with pictures of various coolers, so should give you some ideas on what you may need:
http://www.acousticpc.com/ram_cooling.html :cheers: Hope it helps :thumbup:
Postby JAHGoVeg » Sat Aug 20, 2011 11:49 pm
lol. AcousticPC has some nice things.
Postby hang19840324 » Tue Aug 23, 2011 7:23 am
Thanks for your advice! Now i am using the AMD HD 6970 with a non-stock cooler. I know the fan can solve my problem, but i am still looking for a product that can attach my heatsink on the the VGA RAM but not very sticky, because someone said when they are removing the heatsink, the RAM will peel off together, sound easy to damage my VGA board.
hang19840324
Postby Balzack » Wed Aug 24, 2011 3:53 am
ARTIC G-1 is a thermal glue that has higher heat dissipation rates than thermal pad and easier removal than thermal tape. Check out http://www.youtube.com/watch?v=OZaef91JiIw&feature=youtube_gdata
Hope that helps.
Balzack
Users browsing this forum: No registered users and 276 guests
