POKEMON
POKEMON
Postby skinhead814 » Tue Nov 09, 2010 4:18 pm
All I want to do is play Pokemon and every time I start playing the thing freezes when I try and enter the PC building............HELP
skinhead814
Re: POKEMON
Postby gamfrkI » Tue Nov 09, 2010 6:19 pm
which pokemon game and what emulator are you using
Re: POKEMON
Postby skinhead814 » Tue Nov 09, 2010 8:36 pm
Both Pokemon roms from the Top 10 list do the same thing.......and Boycott Advance......
Probably shoulda mentioned that....my bad....frustration was building
skinhead814
Re: POKEMON
Postby Hot Trout » Tue Nov 09, 2010 9:22 pm
Whice emulator are you using to play the roms?
Re: POKEMON
Postby Kherr » Tue Nov 09, 2010 10:31 pm
I'd suggest using visualboy advance. Haven't had a single issue with that emu... ever. Played every pokemon game from both the GB/GBC and the GBA and never ever had any issues. I'd just suggest downloading that from us and giving it a try. :3
Re: POKEMON
Postby Guest » Tue Nov 09, 2010 10:37 pm
Kherr wrote:I'd suggest using visualboy advance. Haven't had a single issue with that emu... ever. Played every pokemon game from both the GB/GBC and the GBA and never ever had any issues. I'd just suggest downloading that from us and giving it a try. :3
I second that idea. Just downloaded it to test and worked fine :thumbup:
Re: POKEMON
Postby DarthArdios » Fri Mar 23, 2012 1:34 am
I use VisualBoyAdvance, and I can get Gameboy games to work but not Gameboy Advance. The GBA files are .7z format, and i have no idea how to get them to load. Help is GREATLY appreciated
DarthArdios
Re: POKEMON
Postby te_lanus » Fri Mar 23, 2012 2:28 pm
DarthArdios wrote:I use VisualBoyAdvance, and I can get Gameboy games to work but not Gameboy Advance. The GBA files are .7z format, and i have no idea how to get them to load. Help is GREATLY appreciated
Your problem is it's 7z'ed. Most emu's can't read 7z. Un7z it and try it without any compression. If me memory is not to vague VBA only support zip compression
Re: POKEMON
Postby DarthArdios » Fri Mar 23, 2012 10:01 pm
How do I un7z a 7z file?
DarthArdios
Re: POKEMON
Postby gamfrkI » Fri Mar 23, 2012 11:36 pm
DarthArdios wrote:How do I un7z a 7z file?
you can use 7zip http://www.7-zip.org/
or winrar http://www.rarlab.com/
Users browsing this forum: No registered users and 43 guests
