PSX Needs new emulation!
Re: PSX Needs new emulation!
Postby PMJPlay » Tue Jun 17, 2014 1:37 am
Sorry nothing we can do about that...
Postby Hot Trout » Tue Jun 17, 2014 1:30 pm
You can emulate them any way you like but the image of the game will always be the same size unless you remake it.
Postby Hot Trout » Tue Jun 17, 2014 5:20 pm
HARDY88AU wrote:Yeah true is just annoying that i can fit all my N64 and Snes etc but like 10 PSX roms on my phone lol
Give it 12 months and you probably will be able to the speed that phones are progressing.
Postby phaedonos1985 » Fri Aug 01, 2014 4:47 pm
does anyone know how to connect a PS4 controller to work on psx if possible
phaedonos1985
Fav System: ps1
Postby Dragon Mech » Fri Aug 01, 2014 5:32 pm
it is not possible to connect a PS4 controller to a PSX because the PS4 controller is completly wireless. if you need another controller for your PSX, i suggest you use a PS2 controller or find a company that makes hardware for defunked systems. :bowser:
Postby PMJPlay » Sat Aug 02, 2014 12:46 am
You should try Hyperkin which sell new hardware for old systems and they are famous for making the RetroN 5 which is 5 old consoles in one.
The RetroN 5 plays Gameboy, Gameboy Color, Gameboy Advance, Famicom, Super Famicom, Nintendo, Super Nintendo, Sega Genesis, and Megadrive cartridges with enhanced resolution, improved interpolated sound, screenshot capture, and the ability to have on the fly save states.
www.hyperkin.com
