- Code: Select all
http://web.archive.org/web/20001203075700/http://www.cheatcc.com/gb/pokemongs.html
http://www.hayastan.com/games/cheats/cheat15825.html
crustyasp46 wrote:Time Cheat
Change the time. You can only change daylight savings time right. At the title menu press Down, select, B and it will ask if you would like to reset your clock.
Set Your Clock For Daylight-Savings
Return to your house and talk to your mother. She will ask you if you want to set your clock to Daylight-Savings time.
Source :
- Code: Select all
http://www.legendarypokemon.net/pass
Dragon Mech wrote:the password calculator at the site you posted worked perfectly crusty. thanks
