N64 Portable
N64 Portable
Postby rikdegraaff » Fri Apr 30, 2010 7:43 pm
Hi All,
I have a question.
I'm in search of a handheld, that can play N64 roms..
Can the Dingoo or the GPXWiz that? Or what handheld do I need???
I hope that you can help me!
Greetings from a cold Holland,
Rik
rikdegraaff
Re: N64 Portable
Postby Kherr » Fri Apr 30, 2010 9:21 pm
The Pandora can, but it's not out yet, and it's expensive as hell.
http://www.openpandora.org
Re: N64 Portable
Postby The Shadow Dragon » Sun May 02, 2010 6:44 am
Wow that Pandora thing is cool. The best way I could recommend N64 on the go is an emulator on iPod Touch, iPhone, iPad, or PSP, but any of them would have to be jailbroken to do it. You can search quickPwn for iPod/iPhone, or Pandora Battery (no relation to that handheld) for PSP.
Steam: PirateBear
The Shadow Dragon
Has thanked: 9 times
Been thanked: 15 times
Fav System: Dreamcast
Re: N64 Portable
Postby Guest » Sun May 02, 2010 7:20 am
Pandora is neat but as Kherr mentioned, expensive. Your best bet by far for clean emulation is a PSP which can be picked up on ebay for relatively cheap. And then if you have any problems with the jailbreaking process, well thats why we are here. To help!
Re: N64 Portable
Postby Hot Trout » Sun May 02, 2010 9:50 am
What about the DS, what can be emulated on it. The new DS XL is also very cool.
Re: N64 Portable
Postby Guest » Mon May 03, 2010 5:14 am
I was lookin around and right now there isnt much that the DS can do that I know of. I read that emulation is in the early stages. But ive also read that it can emulate DOS. so thats nice
Re: N64 Portable
Postby JAHGoVeg » Tue Jun 15, 2010 9:14 pm
Well as for the iPod touch I have a third generation ipodtouch running jailbroken 3.1.3 firmware and the n64 emulation is kinda laggy so idk
Re: N64 Portable
Postby Guest » Wed Jun 16, 2010 7:28 am
Thats the limitations of an ipod touch for ya...
Re: N64 Portable
Postby labrax » Sat Aug 28, 2010 3:08 pm
Wii can run n64 games. its cool
labrax
Re: N64 Portable
Postby Guest » Sat Aug 28, 2010 3:23 pm
labrax wrote:Wii can run n64 games. its cool
Good point :thumbup:
Thats what I did. But this also does require you to jailbreak the wii, which isnt that bad at all
Users browsing this forum: No registered users and 43 guests
