PSX - Controller Compatibility
Postby Deagonx » Mon Aug 08, 2011 2:59 am
I have a Xbox 360 wireless controller reciever that lets you connect an xbox 360 controller to your computer. And you can configure it to work with games.
Does PSX have such features? I mean. Can I connect the controller and be able to play a game with it?
Thanks in Advance - Deagonx
Deagonx
Fav System: Xbox 360
Re: PSX - Controller Compatibility
Postby BlueMaxima » Mon Aug 08, 2011 3:05 am
If you're talking about a PS1 / PS2 controller, you can go and look up "PS1/2 controller to USB converter" on eBay.
If you're talking about a PS3 controller, look here: www.motioninjoy.com
BlueMaxima
Been thanked: 36 times
Fav System: ZX Spectrum
Postby Deagonx » Mon Aug 08, 2011 3:08 am
No, what I mean is I have a Xbox360 to USB adapter
Can I get it to work for PSX? Because they have virtually all the same buttons, just a somewhat different placement.
Deagonx
Postby BlueMaxima » Mon Aug 08, 2011 3:11 am
Oh, yes, you can.
Do you use ePSXe, pSX, or another emulator?
BlueMaxima
Postby Deagonx » Mon Aug 08, 2011 3:12 am
ePSXe
Deagonx
Postby BlueMaxima » Mon Aug 08, 2011 3:16 am
I believe ePSXe has a way of mapping the keys in it's controller configuration - can you try plugging your controller in, going to the controller setup screen, clicking one of the buttons (as if you were setting that button) and pressing the button on your controller?
BlueMaxima
Postby Deagonx » Mon Aug 08, 2011 3:52 am
Yes, I see what you mean. Map the controls so that they correspond with the PSX controls.
Deagonx
Postby BlueMaxima » Mon Aug 08, 2011 4:20 am
Pretty much, since ePSXe supports mapping to DirectInput (or whatever it's called) that should work just fine.
BlueMaxima
Postby arinlares » Wed Nov 09, 2011 10:53 am
All that matters is your OS picking it up as a controller. I use a PS2 controller with an adapter for my needs, and it kind of works with pSX, which I don't use anymore.
I kept getting an issue with the controller not being detected by the "console" when I pressed L1.
arinlares
Been thanked: 5 times
Postby Kherr » Fri Nov 11, 2011 4:14 am
With ePSXe 1.7.0 I noticed that it didn't quite recognize my corded 360 controller fully. I would just suggest picking up a logitech controller that has rumble and the analog sticks because mine works fully with ePSXe 1.7.0. :3
The Logitech controller I have only cost me $10 USD. :3
Users browsing this forum: No registered users and 156 guests
