PS1 burn to hard-modded system?
Postby plr » Fri Mar 11, 2011 8:28 pm
First off thanks for any response. My question is how to burn isos (or whatever format) to an old modded PS1. Obviously we're talking original PS1 games--or PSX, if that makes a difference--but if you know how to convert 8, 16, or other 32-bit games to play on it I'd be glad for the help. Thanks again. --Plr.
---For anybody else out there having similar trouble: make sure your burner doesn't override your speed setting.
plr
Fav System: PS1
Re: PS1 burn to hard-modded system?
Postby gamfrkI » Fri Mar 11, 2011 9:04 pm
just use a cd burning program and burn at 1x speed
Postby TheGarrison89 » Mon Mar 28, 2011 2:37 am
If you are using the stealth chip, just burn slow (1x) on a reliable media and you should be good to go!
Reliable media means not some store brand disk, rather Sony, Verbatim, Hp, and a few more.
Avoid Imation(spelled correctly) and LG disks, they tend to have a high failure rate.
The reason you want to use a reliable media verses a cheap brand is simple, lower failure rates while burning and less of a risk of your disk not working mid game. However if you do not have a higher tier brand available, other brands will work, just have a higher chance of failing.
Enjoy!
TheGarrison89
Next LVL Up at : 15
Next LVL Up at : 15
Postby Guest » Mon Mar 28, 2011 4:39 am
@TheGarrison89 Good point. The same thing was said about the wii for the people that could actually play burned games on their system (not me >.<)
Burning on a lower speed (1X) allows for less chance of errors
