Old computer game played in school
Postby joe_joe » Thu Mar 03, 2011 5:06 am
Hello guys,
I am trying to find an old game I played in Junior High on the computer. I don't remember if it was on pc or mac. Not sure what type of computer was used in schools back then. This would have been early to mid 90's. I live in the US.
The game: You played against the computer. You and the computer had a cannon randomnly placed on either side of the mountain and you took turns shooting at each other. You could change the angle and the power. It might have been a green color and there was an outer box. Wouldn't mine playing it for ole times sake. Thanks.
joe_joe
Fav System: SNES, GC
Re: Old computer game played in school
Postby Hot Trout » Thu Mar 03, 2011 10:19 am
I think you mean Scorched Earth on the IBM PC. An earlier version of this type of game was Artillery for the Apple II. There was also a later version of Scorched Earth called Scorched Earth 3D which was very nice.
Scorched Earth (1991)
There are three versions of Scorched Earth in the PC Abandonware section of our roms. Link Below.
http://www.theoldcomputer.com/roms/inde ... OS/Games/s
Enjoy :good:
Postby joe_joe » Fri Mar 04, 2011 5:52 am
Thanks Hot Trout. I believe I played artillery. Once I saw the name, I remembered it. Is that still available as well?
joe_joe
Postby te_lanus » Fri Mar 04, 2011 8:03 am
Found This one in another place
Artillery_Ballistics_DiveBomber_FlocklandIslandCrisis_LaserWa.zip
(53.19 KiB) Downloaded 361 times
Postby Hot Trout » Fri Mar 04, 2011 9:08 am
Do a search for Artillery using our search bar in the roms section and you should find more than one version. The Apple II version is available for sure.
Glad to have helped.
Postby joe_joe » Sun Mar 06, 2011 5:53 am
I'm having trouble. Don't have a high level of dl. I'm using a mac with Safari. Do I need to use windows?
When clicking the artillery attachment, I dl it. Then open it and it says There is no default application specified to open the document Artillery_Ballistics_DiveBomber_FlocklandIslandCrisis_LaserWars_LazerBlaster_MoonLanding_SkyBombers_TankCommand_TombstoneCity-2.dsk.
For the scorched earth I dl them. Then open and it opens a folder to a bunch of other folders.
Help please.
joe_joe
Postby te_lanus » Sun Mar 06, 2011 6:33 am
Hi Joe-Joe
For the Attachment you'll need a emu like applewin (http://applewin.berlios.de/) (MESS could also be used, if you use something else than Windoze).
The Scorched Earth files you'll Need Dosbox(http://www.dosbox.com/). Mount the Folder with
Mount c dos
(dos is the Folder where you've extracted the Folder.) From within Dosbox. then use it as normal dos
Postby joe_joe » Sun Mar 06, 2011 9:13 pm
Thanks everyone. I'll have to have a friend help me.
joe_joe
Users browsing this forum: No registered users and 85 guests
