Downloaded adf files not working?
Postby chas53 » Mon May 10, 2021 3:49 pm
Hi all
I am new to Emulation and i am using Win uae. I have quite a few HDF roms but not all work so i was looking for adf files and found this site. I have downloaded 5 files and none of them work. I keep getting a red box at the top of the screen as below:
Software Failure. Press left mouse button to continue.
Error: 8000 0006 Task: 00203290
Can anyone help?
chas53
Re: Downloaded adf files not working?
Postby Hot Trout » Mon May 17, 2021 11:49 pm
Most likely you have not set up the Amiga emulator with the correct Work Bench, OS, memory or CPU setup. Search the internet for some examples and you should be able to get up and running easily.
Users browsing this forum: No registered users and 63 guests
