by slopesoden » Fri Nov 26, 2010 9:46 pm
Hi.
I just downloaded your C64 emulator. It works friggin' great.
However, I have WMP11 and for the life of me I can't figure out how to listen to my music while playing the emulator. I belive it is CCS64 V3.8. Only the active screen has volume, which is the emulator. Any other program will let WMP run in the background, which it still does, and let the music play though the speakers, which it does not.
Any ideas?
Thanks.
slopesoden
- Next LVL Up at : 5
- Has thanked: 0 time
- Been thanked: 0 time
by JAHGoVeg » Sat Nov 27, 2010 6:58 pm
What Operating System are you running? and if possible can you tell us if its 32 or 64 bit.
Thanks,
Jose
- Unlimited Member
- Next LVL Up at : 850
- Has thanked: 63 times
- Been thanked: 97 times
- Fav System: SNES
by slopesoden » Wed Dec 01, 2010 3:27 pm
Hey, sorry about the delay. Had a couple days off. Thanks in advance for your help.
I'm working with XP Home SP3. 32-bit. The machine is an old P4 1.5GHz with 768 MB of RAM. My other emulators, zsnes and jnes, both don't have this issue. Actually WMP works fine during anything else I do. Not too often you hear of a satisfied WMP user, eh?
slopesoden
Users browsing this forum: No registered users and 192 guests
