Spectrum Hardware Index
Postby crustyasp46 » Tue Jan 20, 2015 3:21 pm
Spectrum Hardware Index - A
Name: Abacus Controller
Manufacturer: Abacus Electronics
Price: £14.95
Blurb: Single switch selection for Load/Save/Amp.Built-in amplifier and loudspeaker boosts Spectrum sound output.
Source: Sinclair User Oct 83
Manufacturer: Stephen Adams
Price: £9.00
Blurb: Allows you to add any Sinclair compatible RAM pack to your 16k Spectrum.
Source: ZX Computing Jan 84
Name: Adam II Adaptor
Price: £9.00
Blurb: Updated Adam adaptor allowing 2 devices to be used at the same time. (including any ZX81 interface that uses 0-16k section of the ZX81's memory map)
Source: ZX Computing July 83
Name: ADC8 (Analogue relay switch interface)
Manufacturer: Harley Systems Ltd.
Price: £50.00
Blurb: Input sensitive from 0-10 mV to 0-5V. 8 channels. 40,000 readings per second in machine code. Ideal for data capture & consequencing, control and games. Monitor most variables without needing an amplifier.
Name: Addpac Joystick Interface
Manufacturer: Addpac Electronics
Price: £18.99
Blurb: Standard joystick interface(Kempston compatible).
Source: ZX Computing Aug/Sep 83
Name: ADS Printer Interface
Manufacturer: Advanced Digital Systems Ltd.
Price: £34.50
Blurb: Centronics printer interface. Supports all print commands such as LPRINT and LLIST. Loadable software gives standard text prints and hi-res graphic dumps.
Source: Your Spectrum issue 2
Name: AGF Amplisound
Manufacturer: AGF
Price: £24.95
Blurb: Lead switching amplifier that saves having to swap leads when loading/saving. Includes sound amp, speaker and volume control.
Source: ZX Computing Jun/Jul 84
Name: AGF Joystick Interface II
Manufacturer: AGF
Price: £15.95
Blurb: Proven cursor key simulation for maximum software support. Second joystick facility. Through connector
for other peripherals. Optional tape available to convert non-cursor games to work on the interface.
Name: AGF Programmable Joystick Interface
Manufacturer: AGF
Price: £33.95
Blurb: Programmable - gives total software support. Rear pass-thru port. Select which keys you want to
use, then look up the code on the supplied chart and clip a pair of leads into the interface.
Name: AGF Protocol 4
Manufacturer: AGF
Price: £29.95
Blurb: Programmable joystick interface. Supports AGF, Sinclair, Cursor, Protek and Kempston. Uses 'custom cards' that slot in and 'program' the interface. Cards can be set up by the user.
Source; Your Spectrum issue 11
Manufacturer: AGF
Price: £9.95
Blurb: Allows the use of 'cartridge' games that are used with the Sinclair Interface 2. Basically AGF's version
of Sinclair's Interface 2.
Source: Your Spectrum issue 11
Name: AGF Teletext Adaptor
Manufacturer: AGF
Price: £79.95
Blurb: Receive teltext and telesoftware. Save screens to tape for later viewing. Download software. Includes a
through connector.
Source: Your Sinclair Apr 86
Name: Alphacom 32 Printer
Manufacturer: Dean Electronics Ltd.
Price: £99.95
Blurb: A thermal printer that was the only real rival to the Sinclair ZX Printer. Obeys standard Spectrum commands.120 lines per min. Includes PSU and interface & Through port. Size=7.25in x 3.5in x 3.5in.
Alphacom 32
The following review was taken from ZX Computing Feb 844
The Alphacom 32 printer is the American version of the Sinclair printer, marketed in Britain by Dean Electronics. In size it is nearly twice as deep and slightly longer than the ZX version, and looks an altogether sturdier machine. (actual size 19.4cm x 14.4cm x 7.5cm). The printer comes complete with connector, roll of paper, instruction book and power unit. The PSU being used at the same time as the Sinclair PSU. It also uses all the Sinclair commands; LLIST, LPRINT and COPY.
Having unpacked the unit from its attractive box and read the instructions, the next thing to do was connect it to the Spectrum. The Alphacom connector is larger than the usual connector, having a hump which is flush with the top of the Spectrum when fitted, and a row of spring clips along the underside. These clips do not seem to have any practical use (probably an earthing connection on the American Timex machine) but you have to fit the connector carefully in order not to bend them. The connector has a good tight fir and presented no problems.
Once the paper had been loaded, it was time to switch it on..
The first thing I noticed was how quiet it was. Being used to the ZX's strangulated croak, I was worried that it wasn't working ! But, as the print appeared the other immediately impressive feature became obvious - the speed of print is much faster - two lines a second in fact.
For technical buffs, I'll give the specifications;
Graphics at 80 dpi (256 x n)
Vertical line spacing; 6 lpi
Horizontal spacing: 10 cpi
For non technical buffs, this means the print is slightly thinner and taller !
The print is easy to read with the naked eye, looks very professional and the paper is easy to handle. It does not tend to take a copy of your fingerprints every time you touch it ! The paper is also cheaper than the ZX Printer, at £1.00 per 25m roll.
My smug self-satisfaction was quickly destroyed as the print would not copy well enough to use in the magazine ! However, I wholeheartedly recommend this machine.
Manufacturer: Magenta Electronics Ltd.
Price: £6.98
Blurb: 250mW output via built in speaker. Volume control.
Source: Sinclair User Sep 83
Manufacturer: Advanced Memory Systems
Price: £79.95
Blurb: Three button mouse, interface and software. Usually supplied with, or as part of OCP Art Studio.
Name Manufacturer Price
AMX Mouse AMS £79.95
AMX Mouse
The following advert was taken from Sinclair User - August 1986
As a spectrum user you already enjoy some pretty sophisticated equipment.
So it's a pity if you are still missing that sophisticated, positive control your equipment deserves.
Let's face it, there's not much joy in a joystick, and keyboards can be all fingers and Thumbs. Frustrating, especially if your imagination is much faster than your fingers!
What you need is an AMX Mouse.
Already thousands of Spectrum owners have adopted an AMX Mouse and wouldn't be without it. We didn't claim it was `the best input device'. The press said it for us. In fact it has received outstanding critical acclaim, and no wonder !
The AMX Mouse brings to Spectrum users the same freedom and versatility which has, up to now, been the exclusive province of much more expensive computers.
So, its no surprise that nearly all the new 16 bit `State of the Art' computers now come with a Mouse as standard. Proof, If proof were needed, that The Mouse is here to stay. There are three superb programs included with the Mouse,
AMX ART - Making full use of on-screen windows, ions, pull-down menus and pointers, you'll be astonished at the quality of the work you can produce, save and print using either ZX or Epson compatible printers.
AMX COLOUR PALETTE - The wonderful pictures you create with AMX ART can be brought vividly to life with rich vibrant colours.
AMX CONTROL - Now you can create a `Mouse' environment in your own programs, AMX Control adds 28 commands to normal Sinclair Basic.
There is also a growing list of programs available from other leading software houses, which also utilize the Mouse, including, Artist II and The Writer from Softechnics, and Art Studio from British Telecom's Rainbird software collection, and many more titles will be available soon.
Isn't it about lime you trapped an AMX Mouse?
The following review was taken from Sinclair User November 1986
AMS produces what is easily the most comprehensive mouse package for the Spectrum - the AMX.
It's been around for more than a year and is regarded by many software houses as the standard mouse for their database, spreadsheets and graphics packages. Rainbird has taken this attitude with Art Studio and Softechnics, which currently favours the Kempston mouse, is about to take a nibble at AMX in Aitist II.
It's the best dressed mouse in town with a rugged, easy to grip, body, a long lead which connects to a flat, Kempston-like interface. The interface includes a Cenfronics printer interface which can be controlled with four AMX Basic instructions.
AMX is the only mouse to sport three click keys. They can be independently programmed and AMX uses them to the limit of their potential in its graphics programs.
To prepare the printer option you must type *Mouse Off which stops the interface from generating interrupts when the mouse moves. LPrint and Llist will then send data to your printer.
If you want to list a program, rather than doing a screen dump, you enable die Basic tokens by typing *Tokens command. Your printer may not issue line-feed instructions automatically so the fourth extended Basic command, *LF produces a line feed as well as a carriage return.
The package comes with four artist packages, the simplest of which is AMX Art. Its similar to Rainbirds Art Studio but the icons are displayed at the side of the screen and the three click buttons are programmed. Execute menu option. Leave menu option and Move mouse, and Cancel last order.
Drawing tools include a pencil, paintbrush, paint roller, spray can, palette, text layer and eraser. The pencil can be used to draw lines, the paintbrush can be programmed to use a selection of eight tips which vary in density and width. And the paint roller use textures set up in the palette option. There are 40 textures which can be used to paint lines of varying width on to the screen or fill shapes. The shapes include shaded box and circle.
The text menu gives you access to five type faces which can be printed at normal or double-height, and, if you want to go over the top, in italics. The type forts consist of standard Sinclair character set, Bold, and futuristic 2001.
AMX Art gives more control over its mouse hardware than any of the other packages on the market - which isn't surprising.
For instance the Lock command will trap cursor movement in an invisible grid which has character squares either 4 x 4 or 8 x 8. The former is useful for accurate mouse positioning and drawing long straight lines while the latter enables you to keep colour within attribute boundaries.
Screen pictures can be saved to and loaded from tape or Microdrive. You can store your own effects or load in screens from professional programs.
The package displays all screens in black, white or shade.
To add colour to your designs you'll need Colour Palette. It's a short program but, nevertheless, effective in adding Ink, paper, flash and Bright. Just load in your screen which has been exported from AMX Art and set up the paint brush for the type of colour and effect you require. Then run the cursor over the screen and the colour appears. Ifs as easy as painting a wall.
While paint-and-play is an addictive occupation, particularly with a mouse, you'll soon want to control the AMX in your own programs - won't you !
The AMX Control Program extends Basic to incorporate mouse orientated commands. There are 23 commands which create menus, find out which menu options have been clicked, choose type fonts, display icons, set mouse sensitivity and define screen windows.
The commands are freely mixed with Basic and can use parameters such as variable arrays and codes. AMS has included an icon designer - which works in the same way as a UDG designer. Using it you create and store icons for use within Basic or machine-code programs. There's no reason why you shouldn't even create your own operating system.
It you have problems with the technical side of mouse usage you can load the demonstration program on the second side of the AMS cassette. It shows the type of applications which can be written and shows the considerable power of the package. A four-function calculator and sliding puzzle are written in Basic but for speed and type of application they could equally have been written in machine code. Even my jaundiced eye could not tell the difference.
Manufacturer: Nidd Valley
Price: £34.95 (interface £14.95)
Blurb: Sister mouse to the Digimouse, but uses analogue input. Has three programmable buttons and Z axis. Requires the interface to work.
Source: PCW Feb 86
Manufacturer: Astracom
Price: £166.75
Blurb: Modem. Supports 300/300, 1200/75 and 1200/1200. Auto-scan, auto-answer and auto-dial.
Source: Sinclair User Dec 86
Name: AY Interface
Manufacturer: Stavi
Price: unknown
Blurb: 128k sound (in stereo) on the 48k machines.
Source: Komputer Magazine (Polish) 1986
Re: Spectrum Hardware Index
Postby crustyasp46 » Tue Jan 20, 2015 3:29 pm
Spectrum Hardware Index - B
Manufacturer: Basicare Micro Systems
Price: £45.00
Blurb: Battery backed, real time clock/calander for the Basicare system. Uses the Basic variable t$ to store the time/date and is updated every 50th of a second.
Source: Your Spectrum 84
Name: Basicare Drom (2k)
Price: £39.50
Blurb: Battery backed Non-volatile memory for storing programs quickly. Can also be used for autostart purposes, starting your Spectrum with routines to give special fonts, time etc.. For use with Basicare system.
Source: Sinclair User Aug 83
Name: Basicare Link A
Price: £40.00
Blurb: Eight channel analouge input module for the Basicare system.
Price: £35.95
Blurb: Memory mapping/paging module for the Basicare system.
Name: Basicare Pericon A
Price: £27.90
Blurb: General purpose, user-programmable device providing 24 lines of TTL input/output for the Basicare system.
Name: Basicare Pericon B
Price: £33.75
Blurb: Heavey duty, buffered version of the Pericon A for the Basicare system.
Name: Basicare Pericon C
Price: £41.75
Blurb: Centronics printer interface for the Basicare system. Supplied software allows you to create your own
machine code driver.
Name: Basicare Persona SP
Price: £45.00
Blurb: Initial interface for the Basicare 'Tower Of Power'. Once the interface was connected, you could then add any of the other Basicare modules. Buffered 64-way bus.
Name: Basicare RAM 08
Price: £24.50
Blurb: 8k Ram module for the Basicare system.
Source: Your Sinclair 84
Name: Basicare RAM 16
Price: £26.75
Blurb: 16k Ram module for the Basicare system.
Name: Basicare RAM 64
Price: £76.25
Blurb: 64k Ram module for the Basicare system.
Price: £30.15
Blurb: 3 voice Sound synthesiser for the Basicare system.
Price: £22.20
Blurb: Takes up to 8k of Eproms/Roms Can be used to store your own programs or utils, ready to use at any time.
Manufacturer: Adaptors & Eliminators Ltd
Price: £13.95
Blurb: Protect your programs with this rechargeable, Ni-Cad battery pack and transient suppressor. Keeps the power at 9v, even if the mains goes off. Is able to run your Spectrum for 30 minutes.
Source: ZX Computing Oct/Nov 83
Manufacturer: Hypnotech
Price: £23.95
Blurb: Spectrum amplifier. 8 watt amp with 10 watt woofer.
Name: Beta 128 Disk Interface
Manufacturer: Technology Research Ltd.
Price: £69.95
Blurb: Disk controller with snapshot button to save your programs to disk. Supports both 3.5 and 5.25" drives giving up to 2mb storage.
Source: Your Sinclair Jan 87
Name: Beta + Interface
Price: £249.75 (with disk drive)
Blurb: Disk interface that supports single or double density drives. Operating system on Eprom. Supports 3.5 or 5.25" drives. Runs up to 4 drives.
Source: Sinclair User Jan 85
Manufacturer: William Stuart Systems
Price: £49.00
Blurb: Speech regognition system. large box and mic, as seen on BBC tv 'computer programme'.
Manufacturer: Camel Products
Price: £89.95
Blurb: Eprom programmer. Supports 2516,2716/32/32a/64/64a/28/128a, intel 74a/128a.
Name: Byte Box 1
Manufacturer: Micha Design
Price: £97.75
Blurb: Multi input/output interface. Includes; 4 relays, 1 ADC up to 5 channels, 1 DAC (adjustable) 1 Input port, 1 Output port, 1 Joystick port. All in one box.
Source: Sinclair User Dec 83
Name: Byte Box 2
Price: £137.50
Blurb: Multi input/output interface. Includes; 8 Relays, 2 ADC's up to 10 channels, 1 DAC (adjustable) 2 Input ports, 2 Output ports, 2 Joystick ports. All in one box.
Name: Byte Drive 500
Manufacturer: ITL & Tyrell Systems
Price: £305.50
Blurb: Mass storage system with interface and drive units. 440k storage via 3inch single sided, double density drive. 220k in 11 sectors per side. Access time of arouns 3ms. Interface built into cable includes ULA, 16k ROM and controller chip.
Source: ZX Computing Aug/Sep 85
Note: They planned a double sided version of this unit, anyone know if it ever appeared ?
Postby crustyasp46 » Tue Jan 20, 2015 6:38 pm
Spectrum Hardware Index - C
Name: Cambridge Colt Joystick Interface
Manufacturer: Cambridge Computing
Price: £9.95
Blurb: Standard Kempston compatible joystick interface.
Source: Sinclair User Dec 84
Name: Cambridge Extender Bar
Price: £4.95
Blurb: Extender bar (presumably at the back of the Spectrum), that incorporates a reset button.
Name: Cambridge Intelligent Joystick
Price: £7.00
Blurb: At last a joystick that works ! Cambridge Computing brings you the first programmable joystick at a price you can afford. (requires interface & tape)
Name: Cambridge Intelligent Interface
Price: £24.00
Blurb: Joystick interface. (includes tape) 1k on board memory. Own rear edge connector for printers. Compatible with all standard joysticks.
Name: Cambridge Intelligent Printer Interface (std.)
Price: £39.95
Blurb: Centonics printer interface. Compatible with all standard print commands. Driver software stored in ROM.
Name: Cambridge Intelligent Printer Interface (advanced)
Price: £49.95
Blurb: Includes all features of the standard version + Different sized prints. Grey scale. Downloadable fonts.
Manufacturer: Custom Cable International
Price: £15.00
Blurb: Light pen. Software allows screens to be stored and recalled to create animations.
Source: Sinclair User Aug 84
Name: CCI Programmable Joystick Interface
Price: £15.00
Blurb: Programmable via a short Basic program that allows keys to be mapped to the joystick movements.
Name: Celina Elima-Tapeloader
Manufacturer: Celina Ltd.
Price: £14.99
Blurb: Eliminate tape loading errors ! Device that connected between the cassette recorder and the Spectrum to remove unwanted noise for the signal.
Source: Your Spectrum issue 15. June 85
Name: Celina Loudmouth
Price: £12.99
Blurb: Beep amp for the Speccy.
Name: Centronics Interface
Price: £34.50
Blurb: Centronics printer interface.Supports all printer commands from BASIC.
Manufacturer: Challenge Research
Price: £64.95
Blurb: Looks like a standard cassette recorder, but plugs into the user port and gives up to 4 times load/save speed. Uses normal cassette tapes and is fully compatible with all existing software. Average 48k program loads in 75 seconds.Also includes a replacement ROM with faster load/save routines. It later became apparent that newer 'turbo-loader' software such as the older Ultimate titles, were not compatible. (Feb 85)
Source: Sinclair User August 84 and 16/48 mag (issue 12)
Challenge Sprint
Note: Two versions of this device were produced. Both adverts are included.
The following advert was taken from Sinclair User August 1984
It loads Spectrums four times faster than an ordinary cassette player,
uses standard cassette software,
and has improved loading reliability.
All for just £64.95
The new Sprint from Challenge Research will load and save Spectrum programs at four times the speed of conventional cassette players, this even applies to standard program and games software that has been pre-recorded at normal speed. All this plus improved loading reliability is available for just £64.95 inclusive of post, packing and vat and 12 month guarantee.
The Sprint is dedicated to both 16k and 48k Spectrum and provides an innovative but inexpensive new concept is cassette tape storage.
Use of the Sprint is simplicity itself:
> Retains the standard Spectrum commands and format.
> Advanced digital circuitry and signal processing improves loading reliability and eliminates volume setting.
> Simply plugs into the Spectrum port - no interface or external power units required. It even has its own expansion slot so that you can still use other peripherals at the same time.
> A full 48k program will load in 75 seconds rather than five minutes with a conventional cassette recorder.
Spend less on a Sprint.
Spend more time working your Spectrum and be the envy of your friends.
The following advert was taken from Sinclair User December 85
The SPRINT high speed data recorder;it loads Spectrums four times faster than an ordinary cassette player,and four times cheaper than an the average disk drive.
The new MkII Sprint loads and saves programs on the Spectrum four times than conventional cassette recorders. It even loads commercial and home recorded programs at high speed and they don't have to be resaved to do so !
The tape format and data density on the tape is not changed with the Sprint so programs saved at speed can be loaded on a standard recorder though at the normal rate.
The new Sprint is now Interface 1 and Microdrive compatible to further increase it's versatility and so provide an innovative yet inexpensive new concept in program storage.
USE OF THE SPRINT IS SEMPLICITY ITSELF:
° Retains all standard Spectrum commands in an inaltered form.
° Uses no ram and no extra programs have to be loaded beforehand.
° Advanced circuitry eliminates volume setting.
° Simply plugs into the Spectrum port, no interface or external power required.
° Has its own expansion slot so you can still use joysticks, printers and other type of peripherals.
TECHNICAL SPECIFICATIONS:
° Loads all programs of reasonable quality and standard tape format. Will not work with "hyper load", etc. unless resaved to standard format.
° Off-line swich fitted to disenable the Sprint whilst the Spectrum is running.Allows compatibility with standard recorders, microdrives and other peripherals with internal memories.
° Accepts standard commands.
° High quality injection moulded black ABS case with spark erode finish to match Spectrum case.
° Inbuilt 56-way rainbow cable with gold plated contact edge connector for linking to Spectrum.
° Full 56-way expansion slot on rear of Sprint (identical to Spectrum one).
° Tape speed 19 cm/sec.
° Enhanced fast forward and rewind speed.
° Auto-stop system built-in.
° Dimensions: 190 mm long x 143 mm wide x 60 mm high.
The following review was taken from 16/48 tape magazine December 84
The Sprint recorder is a device consisting of a normal tape deck which runs at 4 times standard speed and a replacement Spectrum ROM. The ROM has a modified cassette interface routine which SAVES and LOADS at Four times normal speed.
The clever part is that the same Format is used, just the speed is changed. This means that programs saved on the sprint can be loaded on a normal system and vice versa.
The recorder seems reliable with most commercial programs, but lack of an asimuth adjustment means that you may have trouble with some other tapes.
The unfortunate development for Challenge is the advent of custom loaders on much of the current software. These newer tapes will not load, and unless Challenge can persuade all the software houses to agree on a single Fastload standard the SPRINT will never totally replace the recorder you are using now.
If you like the idea of reducing the loading time of 16/48 or even SABRE WULF by a factor of four, then so long as you keep your old recorder handy, this is still an investment worth some consideration.
Name: Challenge Sprint Mk II
Manufacturer: Macway Ltd
Price: £69.95
Blurb: Same as the original Sprint but with Interface 1 compatibility.
Source: Ruggiero Antonio - Sinclair User Dec 85
Price: £49.00
Blurb: Speech synthesis interface. Genuine phonetic synthesis. Unlimited vocabulary. Self contained speaker/amp.
Price: £39.00
Blurb: "It can say anything. Genuine phoneme synthesis - not just recorded speech - hense unlimited vocabulary. Programmable pitch for more natural intonation. Solid tone cabinet for quality sound. Internal BEEP music amplifier. Expansion socket for 'Big Ears' voice recognition system."
Source: Your Computer March 85
Name: Cheetah 32k Ram Pack
Manufacturer: Cheetah Marketing Ltd.
Price: £39.95
Blurb: A ram upgrade to 48k. Simply plugs into the rear connector and gives full 48k.
Name: Cheetah 68FX1 Keyboard.
Price: £59.95
Blurb: 65 key full travel keyboard with single shift keys and full length space bar. 13 single key functions. True shift-lock. Space for Interface 1 inside.
Note: This keyboard is sold by Cheetah, made by London Microtech ltd. and marketed by Fox Electronics.
Name: Cheetah Defender Light Gun
Price: £24.95
Blurb: Now you can fire a plastic gun at the telly ! Includes several games like Bronx Street Cop and Billy the Kid.
Source: Your Sinclair Nov 89
The following review was taken from Your Sinclair November 89
As we all know, lightguns are basically a fun, if limited addition to Speccy gamesplaying. First off the mark was actually the Stack Light Rifle years ago, but it was a bit crap. The biggie of course was the recent Amstrad/Spectrum Light Phaser. But that had its disappointments too, namely the rather flimsy construction and horrible black and white bars it splattered across Operation Wolf.
It was only a matter of time before a joystick company entered the fray, and the first of these to do so is the popular joystick and funbox maker Cheetah Marketing.
The Defender is a nice piece of work. The moulded plastic body is dark grey with bright red handgrips. The design is quite modern and sturdy looking I s'pose, but still with slightly naff Buck Rogers-like tendencies. The hand grip is raked forwards to make it slightly easy to aim and hold, and weights have been added inside the body to improve the feel and balance.
Accuracy-wise, the Defender seems to be pretty sharp. Most of the time I aimed at something I hit it, which means one of two things - either the gun is accurate, or the software is really good at reading the gun. You do have to be fairly square to the screen, and not too close, or the focus of the gun goes all to cock.
There are six games bundled with the gun, Jungle Warfare, Advanced Pinball Simulator, F16 Fighting Falcon, Supercar Trans Am, Bronx Street Cop and Billy the Kid.
In conclusion, the Defender looks better and is cheaper than its current competitor, the games are better and its generally more fab !
Name: Cheetah Hi-Stak Feet
Price: £2.99
Blurb: Angled plastic feet for your Spectrum.
Note: A similar device by the same name was produced by a company called Warp Factor Eight of Herts. and advertised in Sinclair User Feb 83.
Name: Cheetah Megasound
Price: £10.95
Blurb: Amplifies your sound via the TV speaker.
Name: Cheetah Midi Interface
Price: £49.95
Blurb: Midi in/out/through. Midi delay. Control any midi instrument. Forward & reverse sequence playback.
Manufacturer: Cheetah Marketing ltd.
Price: £29.95
Blurb: Remote Action Transmitter. Infra red game pad that can be used for games. Kempston compatible.
Cheetah RAT
The following article was taken from Home Computer Course 1984
Cheetah Marketing is a company with a good track record in producing add-ons for the Sinclair Spectrum - the Sweet Talker synthesiser is the most successful to date. The RAT, a remote-controlled joypad that uses infrared waves, is the company's latest achievement. We look at this addition to the home computer menagerie....
Serious arcade games players tend to be very concerned about anything that significantly affects the speed and quality of their play - especially if its has a noticeable impact on the final score. For this reason, the way in which a game is controlled is a matter of great importance. With games controlled from the keyboard, the major concerns are the choice of control keys and the ease with which these can be used. Consequently, software writers must pay particular attention to this sort of detail. With external controllers, like joysticks, the design of the hardware tends to be the crucial factor.
The flexibility of a joystick - its freedom of movement, how quickly it reacts to your touch, the speed at which the game responds - is its most significant design consideration. But the designer is often hampered by the limitations imposed by the nature of a joystick itself - the length of the connecting lead, the size, shape and position of the controller, and the positions of the fire button/s. The latter detail for example, often favours right-handed players. Although joystick manufacturers have tried to develop designs that overcome some of these drawbacks, none have been as successful as Cheetah Marketing's infrared remote joypad for the Sinclair Spectrum.
Cheetah has called its joypad the RAT. The name is said to be an abbreviation for 'remote action transmitter', but seems to be a play on the word mouse, which is applied to hand held controllers used with Apple's Macintosh and other machines. The RAT looks like a slightly elongated phaser weapon from televisions Star Trek series. It is long, flat and grey, with a blue circular control pad, the Cheetah logo and a bright orange fire button. There are two infrared transmitters extending from the front of the unit. When you first hold the RAT and press the fire button you almost expect flashes of blue flame to leap from it.
The system also includes its own interface, which plugs into the edge connector at the back of the Spectrum. This box has an expansion port of its own for further add-ons. There is a single infrared receiver on the front of this unit for communicating with the RAT.
The package has a sheet of instructions that explain how the joypad is used and what games can be played with it (any software that is Kempston compatible). With great foresight, Cheetah has included routines in BASIC and machine code that enable you to incorporate RAT control in your own games.
The instruction sheet claims that the RAT can be used at distances up to 12 feet by aiming 'in the general direction of the computer'. Movement is effected by pressing lightly on the blue control pad. There are eight small bumps on the periphery of the pad, and pressing on or near one of these indicates the direction required - N, SW and so on, rather like the directions on a compass. While one hand holds the RAT and controls the direction of movement on the screen, the other can be used to press the fire button. Because of the design of the RAT, it makes no difference which hand performs each task, so the joypad works equally well for left-handed and right-handed players. The transmitter requires one PP3 battery, which fits into a small space at the back of the unit.
Once the interface box is connected, the transmitter unit has been fitted with a battery and a game requiring joysticks has been loaded into your Spectrum, then you are ready to play. The transmitter works extremely well at distances even slightly over 12 feet. Clearly the Cheetah RAT gives a games player a tremendous freedom to move around. The biggest drawback, however, is that it has only eight positions of movement - up, down, left, right and intermediate points. It would be better to have more control than this.
At £29.95, the Cheetah RAT costs only slightly more than most joystick and because it has no moving parts, should last a bit longer as well.
Name: Cheetah Sound Sampler
Manufactyrer: Cheetah Marketing
Price: £44.95
Blurb: Sound sampler unit with microphone. Allows mixing of samples, forward or reverse, edit, reverb and echo effects. 17.5Khz bandwidth.
Source: ZX Computing October 86
Price: £29.95
Blurb: Digital drum system for your Spectrum. 8 digital drum sounds. True digital drum machine. Extra sounds can be loaded from tape. Real time or on-screen programming. Store over 1000 rythms.
Cheetah Specdrum
The following review was taken from Popular Computing Weekly October 1985
Cards on table time. I am biased towards all things musical on micros because it seems to me to be one of the genuinely fun things micros can do.
Whereas it is now quite cheap to get yourself a useful little Casio keyboard, the pre-set drum sounds are usually useless. Almost without exception drum sounds on the cheap keyboards are so irredeemably Neanderthal, idiotic and plastic sounding that only those people whose ultimate objective in musical life is to play When the Saints Go Marching In, will find it satisfactory.
Conversely, though, decent drum machines can, cost you £300 plus.
Cheetah has now produced an answer. Specdrum gives you, in conjunc-tion with a Spectrum, an excellent drum machine that uses sampled sounds (real drums digitally encoded) which can be played either in real time or notated using a simple screen editing system.
The Specdrum system comes with a 'kit' of eight sounds bass drum, high hat open, high hat closed (chik and toosh respectively) hand claps (shak), snare (thwak) cowbell (ching), mid tom (thom), low tom (domp) and hand claps (krkkkk). Up to three of these sounds can be used simultaneously but in fact the illusion of everything happening at once is quite possible with a bit of smart programming around the beat.
The software that gives you control of all this is mainly excellent. The display lets you choose a song to work on and name it, starting either from scratch or loading in saved drum patterns from tape. Composing a song (which means an ordered sequence of different patterns) is a matter first of crating the individual drum sections then structuring the completed patterns according to the layout of the music you want to use them with.
The pattern creation section works in two ways. You can either work in real time, choosing and inserting each different percussive beat and building up a complete pattern over a specified number of bars or you can enter each beat using cursor keys on a simplified equivalent of a musical stave.
The excellent part of all this is that the real time and notation ways of working are completely interrelated - your real time drum inputs are automatically notated for you so it is possible to mix the different kinds of inputs easily. This means that the easy-to-play bits like a regular snare pulse can be quickly tapped out in real time and some tricky twiddly bits car be carefully notated.
The individual patterns are then 'filled' and numbered and then Saved to tape.
The only criticism I have of the software is that there are some occasions where you go into sub menus and discover that options that are not currently available stay on the screen, eg, often option D for drum play is shown, but pressing D won't do anything until you have 'returned' from some sub menu. It's basically a small point.
The sounds are excellent and it does help if you have a decent amp or hi fi. You'll will need some sort of amplifier whatever you do though - the Specdrum sends its sound signal out via a standard phono lead.
There is promise by Cheetah too, of other sounds on tape for around £3 to give you a totally different kind of drum section.
You can, even synchronise your Specdrum to other instruments - it will produce a click impulse into the Spectrum Mic socket. This pulse - put into a multitrack or on to tape could form a click track to trigger Sequencers but the manual is unfortunately very vague On this point. I think you'd need a sync box tough - the manual is not helpful on this point and I'd have welcomed a lot more information.
This peripheral should be treated with unrestrained glee by Spectrum owning music buffs.
A decent drum machine for £29.95? Ridiculous!
Name: Cheetah Sweet Talker
Price: £29.75
Blurb: Make your Spectrum talk ! A speech interface based on the Allophone system.
Source: Sinclair User May 84
Name: Chroma 1 Monitor
Manufacturer: Chromagraphica
Price: £249.95 (extra £17.50 for sound)(£28.95 for Speccy converter)
Blurb: High res 14" colour monitor (585x895)
Source: Sinclair User June 86
Name: Clive Drive, The
Manufacturer: Ergo Systems Ltd.
Price: £59.95
Blurb: Disk interface with drive and printer port. Responds to all standard drive commands. Uses double sided drive allowing 50k per side. (100k per disk). Average loading time was 13 seconds.
Source: Crash 59. Dec 88
Note: This device was later sold by Video Vault, with an added back-up button. (Nov 89)
Name: Clive Printer, The
Price: £40 (approx)
Blurb: 80 character thermal printer. Dot addressable graphics. Inverse option. Expanded print option (160 chars). Uni or Bi directional.
Source: Crash 59. December 1988.
Note: This was a option when buying the Clive Drive, and could not be used without it.
Manufacturer: Jiles Electronics
Price: £99.95
Blurb: Allows tape to tape copying by connecting two recorders to the unit.
Name: Cobra RS232 Interface
Manufacturer: Cobra Technology Ltd
Price: £26.85
Blurb: Standard RS232 interface.
Source: ZX Computing Apr/May 83
Manufacturer: Cole Computing
Price: £12.00
Blurb: 110/300 baud RS232 output port.
Source: Sinclair User Feb 83
Name: Comcon Programmable Joystick Interface
Manufacturer: Frel Ltd.
Price: £17.95
Blurb: Programmable joystick interface for the Spectrum.
Source: Crash 4 (may 84)
Price: £22.95
Blurb: Twin version of the Comcon Programmable, Having two ports.
Source: Sinclair User Jun 86
Manufacturer: Computer Add-ons
Price: £4.50
Blurb: Designed to tilt your Spectrum to a better working position.
Manufacturer: Kelwood Computer Cases
Price: £11.85
Blurb: Takes the heat out of your Spectrum. Lets your machine run cooler.
Source: ZX Computing Feb/Mar 84
Manufacturer: Citadel Products
Price: £23.95
Blurb: Internal ram upgrade for your Spectrum. Gives 48k.
Source: ZX Computing Jun/Jul 83
Price: £89.95
Blurb: Software paged 16k non-volatile Ram. Store programs quickly and simply.
Name: Crescent 128 Quick Disk
Manufacturer: Servicon Dynamics Ltd.
Price: £117.44 (drive) £152.69 (interface)
Blurb: Another alternative to the microdrive claiming upto 20 times the speed. Stores 128k of data and can read 65k in 4-8 seconds. Has RS232 port and RGB port. Allows only 2 drives to be attached to the interface. An enhanced version (256i) could store 256k and cost £229.90
Source: Your Spectrum issue 15 June 85
Name: Crescent 401 + 2000DFS
Price: £129.95 (£199.95 with DFS os)
Blurb: Disk interface supporting 3" and 5.25" drives. DFS features upto 78 files (200k). Extended Basic commands. True random access. Uses 8k of Ram.
Source: Sinclair User Feb 85
Name: CS-DISK Interface
Manufacturer: Circuit Design. (Danmark, 1985)
Price: unknown
Blurb: Also known as the `CD-DISK', it is able to control 4 standard double-density floppy drives as well as equips the Spectrum with CP/M compatibility. Furthermore it contains a Centronics printer interface and an interface for an IBM PC keyboard (which only works in CP/M). Formatting, copying and so on is done through CP/M programs.
Name: Currah MicroSlot
Manufacturer: Currah Computer Components
Price: £14.95
Blurb: Splits your expansiion bus into two allowing two peripherals to be fitted at once.
Name: Currah MicroSource
Price: £44.50
Blurb: FORTH and Assembler cartridge with debug.
Currah Microsource
The following article was taken from Your Sinclair Issue 6 - June 1986
Now this is clever - a ROM pack that plugs into the Speccy to give instant access to an assembler and a debugger plus a noddy version of Forth.
Unlike assemblers that load from tape, this one doesn't take up valuable memory and it doesn't go away when you crash the Spectrum. Neat huh ? The assembler itself is excellent; two-pass assembly, macros and conditional directives as well as complex maths in hex and decimal. You can assemble or list to the screen and memory or out to any OPENed stream - such as a microdrive file or a second Spectrum connected via the interface 1. Shame the editor is so naff; you enter your source program as a normal Basic program, each line beginning with REM ! It works but the screen get very messy. And you don't get useful things like the block move, find, auto-number and so on. To assemble your program you enter the line LET assemble=1 before your source lines and run the basic program.
The debugger's also excellent - it gives you a full screen 'front-panel' disply showing all the Z80's registers and relevant memory location. You can single-step or trace your program or execute it to a certain point, all the time seeing whats going on inside the machine. Or you can opt to watch a block of memory or switch to a more limited register display in order to speed tracing up. There's no disassembler but otherwise it's great - especially recommended for beginners.
Now for the bad news. Microsource Forth is completely potty. You enter your Forth commands as REM # statements in a basic program proceded by the line LET forth=1; to execute them you RUN the Basic program. But the idea of Forth is that everything happens the moment you enter it - so there's no stored program as such. And it gets weirder - right down to using % for definitions instead of the : everybody else uses ! It's not fast, it's not interactive, it's not standard, it's not.........
The whole thing comes with an adequate if bland manual but without a through-connector for other add-ons, so it must be the last thing stuck onto your Speccy. Still, if you need a decent assembler/debugger, it certainly shouldn't be the last thing stuck on your shopping list.
Name: Currah MicroSpeech Unit
Price: £29.95
Blurb: Speech synthesis box using the SP0256-AL2 speech processor. Outputs sound via the TV.
Postby crustyasp46 » Tue Jan 20, 2015 7:02 pm
Spectrum Hardware Index - D
Manufacturer: Meow Micros
Price: £24.95
Blurb: Fully compatable (or your money back) cassette recorder for your Spectrum.
Source: ZX Computing Arp/May 84
Name: Datafax Disk System
Manufacturer: Datafax
Price: £245.00
Burb: Interface supports 3 and 5.25 drives. up to 200k storage. External DOS uses 8k of memory. Built-in reset button.
Source: Your Spectrum issue 8
Note: This interface was used in the Statacom Disk System.
Manufacturer: Datapen Microtechnology Ltd.
Price: £29.00
Blurb: Lightpen system. Draw direct to screen.
Source: Your Spectrum issue 17
Manufacturer: Miracle Technology
Price: £47.09
Blurb: Interface to connect a modem to your Spectrum.
Source: Your Spectrum issue 18
Manufacturer: Hirst Electronics
Price: £29.95
Blurb: Transforms the task of loading and saving from a chore to a delight. Small external box between the Speccy and the cassette recorder.
Manufacturer: Procomm Systems
Price: £??? (no price.. just an advert !)
Blurb: Cure Load/Save problems with this easy to use unit. Also includes a 'beep' ampliphier.
Name: Datel 3 Channel Sound Synthesiser
Manufacturer: Datel Electronics
Price: £19.99
Blurb: 3 channel sound interface.
Source: Your Sinclair - Sep 89
Name: Datel Demagnetiser
Price: £9.99
Blurb: Loading problems ? Your tape heads may need demagnetising. Its a cleaner and demagnetiser built into a cassette.
Source: Your Sinclair Aug 88
Name: Datel Digital Sound
Price: £49.99
Blurb: Digital sampling technology on your Spectrum. 8bit sampling and playback of any sound.
Name: Datel Games Ace
Price: £10.99
Blurb: Allows any 9 pin joystick to be used with the Spectrum. Puts sound through TV speaker.
Source: Sinclair User Dec 88
Name: Datel Genius Mouse
Price: £49.99
Blurb: High resolution, two button mouse. Complete with interface and OCP Art Studio software.
Name: Datel Inter Printer
Price: £34.99
Source: Crash 11 (Dec 84)
Name: Datel Lightwriter
Price: £16.99
Blurb: Create superb graphics with this lightpen.
Price: £34.99
Blurb: The ultimate printer interface with built-in word processor (RamWrite). Works with any standard centronics printers.
Price: £49.99
Blurb: Full function 5 axis movement. Includes standard grip jaw, magnetic finger, Shovel attachment and stabilising legs.
Datel Robotarm
The following advert was taken from Your Sinclair December 88
FULL FUNCTION WITH 5 AXIS MOVEMENT
Explore the fascinating science of robotics with this fantastic full featured Robot Arm.
Human like dexterity. . with 5 axis of movement it is so versatile it can manipulate and pick up any object as small as a paper cup or as big as a tennis ball.
Easily controlled using 2 joysticks (any 9 pin type) or connected to your Spectrum with our special interface/software to give computer/robotic control.
Comes with accessories including:
Standard grip jaws to mimic finger type grip.
Magnetic Finger Adaptor with release mechanism.
Shovel attachment for materials handling.
4 stabilising legs for heavier jobs.
Uses 4 HP2 batteries (not supplied) to power motor movement.
Name: Datel Robo Tek
Price: £29.99
Blurb: Robotics and model controller.
Source: Crash 11 (dec 84)
Price: £29.99
Blurb: Transfer all your programs to microdrive or disk at the touch of a button. Datel's version of the Multiface.
Source: Your Sinclair Oct 86
Note: Datel later launched the follow-up, Snapshot 2.
Name: Datel Switchable Joystick Interface
Price: £19.99
Blurb: Switches between Kempston, cursor and Interface 2 types.
Name: Datel Turbo Ace
Price: £22.99
Blurb: Switchable joystick interface with sound booster.
Name: Datel Vox Box
Price: £29.99
Blurb: Speech synthesizer with built in joystick interface. Uses allophone system. Sound output via TV speaker.
Name: DCP Interpack 1
Manufacturer: DCP
Price: £43.43
Blurb: Part of the DCP Control System. The system consists of several packs and additions that can be linked together to form a very powerful external control unit for the likes of servo's, robots etc.. This module contains analogue and digital inputs. An 8bit TTL input and an 8bit TTL output port.
Name: DCP Interpack 2
Manufacturer: DCP
Price: £34.74
Blurb; Part of the DCP Control System. This module contains an eight-switch contact for digital inputs, six SPDT relays and 15way expansion bus.
Name: DCP Interpack 3
Manufacturer: DCP
Price: £43.43
Blurb: The stepper motor control. Can drive up to 3 12v two-phase motors. Also has eight buffered switch contacts.
Name: DCP Interpack ADC Pack
Manufacturer: DCP
Price: £21.70
Blurb: Fast analogue to digital converter.
Name: DCP Interpack DAC Pack
Manufacturer: DCP
Price: £21.70
Blurb: Fast digital to analogue converter.
Name: DCP Interpack Intercard
Manufacturer: DCP
Price: £13.00
Blurb: Used to connect Interpacks together.
Name: DCP Interpack Invertabus
Manufacturer: DCP
Price: £4.30
Blurb: Connects two ADC or DAC packs together.
Name: DCP Interpack Powerbus
Manufacturer: DCP
Price: £17.35
Blurb: Boosts power when several Interpacks are used together.
Price: £199.50
Blurb: Same as the Delta Disk Interface, but with the added 128k memory.
Name: Delta Disk Interface
Manufacurer: Technology Research Ltd.
Price: £129.50
Blurb: Disk interface that supports 3.5 and 5.25 drives. Built-in centronics port. Built-in memory option, allows up to 128k to be added.
Manufacturer: Delta Research Ltd.
Price: £33.00(issue 1). £26.00 (issue 2)
Blurb: Internal Ram upgrade for 16k machines. Easy to install.
Manufacturer: Computerlock
Price: £22.00
Blurb: TV/Monitor stand that incooparates your Spectrum, PSU and tape.
Blurb: Mouse that uses digital pulse output for more accurate movement. Requires one of two interfaces to work, The basic low-cost version (£14.95) or the professional version incorporating a Centronics port and direct link to the Nidd Valley programmable keypad. (£34.95)
Source: PCW Feb 86
Price: £9.50
Blurb: Keyboard enhancer for Spectrum Plus. Replaces the rubber membrane with a tactile feeling alternative.
Name: Disciple Interface
Manufacturer: Rockford Products (designed by Miles Gordon Technology)
Price: £86.59
Blurb: Disk interface allows up to 16mb of storage on 2 drives. Loads full 48k program in 3.5 seconds. Compatible with any standard drive, double or single density. Snapshot button to save your programs to disk. Printer interface. Dual joystick ports. (Sinclair/Kempston). Networking feature to allow the Disciple to act as file server for upto 64 other Spectrums.
Name: DK'tronics 3 Channel Sound Synthesiser
Manufacturer: DK'tronics
Price: £29.95
Blurb: Incorporates a Beep amplifier and 3 channel sound synthesiser.
"The 3 channel sound synthesiser adds a totally new dimension to sound on your Spectrum. It allows you to
program your own music with harmonies, explosions, zaps, chimes, whistles and an infinite range of other sounds over 8 octaves. Based on the popular AY-3-8912 sound chip it gives you complete control (from Basic or M/C) over 3 channels of tone/or white noise, plus envelope and volume control. It comes with its own pod mounted 4inch speaker."
Name: DK'Tronics Beep Audio Amp
Price: £14.95
Blurb: Amplifier interface with pod mounted 4inch speaker and volume control. Looks much like the 3 Channel Sound, but doesn't have the sound chip.
Name: DK'tronics Dual Port
Price: £13.00
Blurb: Dual port joystick interface.
"The first port simulates 6,7,8,9 & 0 keys. The second port simulates IN(31) command" - Kempston.
Name: DK'tronics Games Controller
Price: £12.95
Blurb: Standard joystick interface (Kempston) with the added feature of a 'slowdown' control for games that are just too hard for you.
Source: Your Computer May 85
Name: DK'tronics Joystick & Interface
Price: £22.95
Blurb: Winning is within your grasp ! Cursor & Kempston compatible.
Price: £45.00
Blurb: "The DK Microdrive compatible keyboard is the best selling keyboard in the world and is used by 10% of all Spectrum users. It is Microdrive compatible and offers more key functions than any other keyboard in its price range. The stepped keys and space bar make it even easier to use. It is constructed from high density black ABS and has 52 keys and a full width space bar. A seperate numeric keypad of 12 red keys, including a single entry 'delete' plus single entry decimal point, facilitate fast data entry."
DK'tronics Keyboard
The following review was taken from ZX Computing Apr/May 84
The DK'tronics keyboard is a sturdy, solid-looking, black ABS case with a set of grey alphanumeric keys on the left and a 3x4 red numeric keypad set on the right. The Spectrum is removed from its case by unscrewing the case halves, gently pulling out the two keyboard connecting ribbon cables and unscrewing the two small circuit board screws. The reverse process is then undertaken with the DK'tronics keyboard. Precise instructions are supplied so any incompetent can do it - even I managed !
The keys have a pleasant feel to them, the spring pressure was just about right to allow for my fumbling efforts, and generally the legends supplied on transparent stick-on plastic labels, are easy to read. Some of the smaller red characters - $ %& - may give rise to eyestrain.
My main problem came from the design of the back of the case. The sides slope out slightly but the back slopes out a lot making it difficult, sometimes nigh impossible, to connect units to the user port. I had to make a saw to the case to remove several cm's from between the port and the save/load sockets. Even so, some units that had ridges which normally fir over the top of the Spectrum would not fit without major surgery. The only way to use items such as the Microdrive or the Prism VTX modem which normally fit beneath the Spectrum, was to buy a ribbon cable extension.
Irritating though these problems are, the keyboard is still worth having for general use and is invaluable for any serious typing on the computer.
Name: DK'tronics Light Pen
Price: £19.95
Blurb: Draw in high resolution on your TV screen.
"This highly succesful Light Pen fits neatly onto the rear of the computer. The operating software now runs faster and supports 16 pre-defined instructions. You can change all the colours (border, paper, ink), draw circles, arcs, boxes, lines and insert text onto the screen. There are also features to draw freehand and animate on the 48k Spectrum, you can retain and animate 5 screens. You can also use the machine code on its own in your own programs."
Name: DK'tronics Parallel Centronics Interface
Price: £39.95
Blurb: Allows any printer with a centronics interface to be connected to you Spectrum. Uses standard print commands.
Source: Sinclair User March 85
Name: DK'tronics Programmable Joystick Interface
Price: £22.95
Blurb: "Now you can run any software from any supplier with the DK'tronics fully programmable joystick interface. It comes complete with machine code software and can be programmed in seconds to give full 8 directional joystick movements."
Name: DK'tronics Spectra-Sound
Price: £9.95
Blurb: Fully amplied sound via your TV. Fits inside your Spectrum.
Name: DK'tronics Speech Synthesiser
Price: £24.95
Blurb: Speech synthesiser using the SLO/256 chip.
Manufacturer: F E Electronics
Price: £29.90
Blurb: Create electronic art on your TV screen.
Source: Your Sinclair issue 1 Jan 86
Name: Downsway Programable Joystick Interface
Manufacturer: Downsway Electronics
Price: £22.95
Blurb: Simply move the stick and press the appropriate key to program.
Manufacturer: Evesham Micro Centre
Price: £14.95
Blurb: Back up any program on the Spectrum. Requires 2 tape decks.
Name: Dove Disk Drive Interface
Manufacturer: Dove Microtronix Ltd.
Price: £249.00
Blurb: None available. Help required.
Source: Sinclair User Oct 84
Name: Dove Joystick Interface
Price: £9.95
Blurb: Standard joystick interface. Kempston compatible.
Postby crustyasp46 » Tue Jan 20, 2015 7:10 pm
Spectrum Hardware Index - E
Manufacturer: DIY project in Magazine c't
Price: n/a
Blurb: PCB design for centronics port.
Source: Magazine c't 1986 (supplied by Peter Sieg)
Name: Echo Amplifier
Manufacturer: HCCS (Home and Continental Computer Services Ltd.)
Price: £25.95
Blurb: 5 Watt sound amp with a 6inch speaker. Volume & tone controls.
Source: Your Sinclair Nov 86
Manufacturer: HCCS
Price: £39.95
Blurb: Music keyboard (as in piano). Software to create your own sounds.
Name: Electrotech Joystick Programmer
Manufacturer: Electrotech
Price: £43.70
Blurb: Programmable joystick interface and large black 'controller' consisting of three buttons. 2k ram board stores key-press info & feed the interface.
Source: Sinclair User Aug 97
Name: Eider Systems Pro Keyboard
Manufacturer: Eidersoft
Price: £76.38
Blurb: 67 full travel keys. on/off switch. Reset button. LED indicators. Factory fitted.
Price: £4.90
Blurb: On/off switch. Saves wear & tear.
Manufacturer: Kirk Automation Ltd
Price: £99.95 (modem only) £149.95 (full kit)
Blurb: The modem supports 300/300 and 1200/75. The kit includes interface, leads, viewdata software and terminal software.
Manufacturer: Kirk Automation Ltd.
Price: £249.95 (modem only)
Blurb: Sam features as the Enterprise 1 but also has 1200/1200. No mention of a pack version as with the Enterprise 1.
Source: Sinclair User Dec 86.
Manufacturer: Eprom Services
Price: £19.00
Blurb: Eprom board that takes 8 or 2k EPROMS.
Name: Eprom Programmer
Price: £54.95
Blurb: Eprom programmer that can handle intel eproms.
Name: Eprom Services 32-way Port
Price: £15
Blurb: 32-way I/O port based on the 8255 chip. It uses a standard 24 line port with one output fed into eight flip-flops to gain the extra lines. These extra lines are four pairs which can only be oposite each other. (if four are 0, then the other four must be 1). This port requires a motherboard for connection costing £24.00
Source: Sinclair User Apr 83
Manufacturer: Domark
Price: under £250 (that's what the ad said !)
Blurb: Medium res monitor with sound output. Screen zoom facility.
Source: Your Sinclair May 86
Price: £9.00
Blurb: Allows the Spectrum 48k to use the peripherals of the ZX81 as long as the devices operate in the 0-16k section of the ZX81's memoery map.
Postby crustyasp46 » Tue Jan 20, 2015 7:19 pm
Spectrum Hardware Index - F
Price: £85.00 interface, £185.00 disk drive
Blurb: Disk opperating system in ROM. 100k capacity.
Source: ZX Computing Apr/May 84
Manufacturer: Timex
Price: ??
Blurb: Add on unit containing alot of stuff ! 2 3" drive slots, built-in PSU, 2 RS232 ports, 64k Ram. Documentation supplied also mentions ULS'a and a Z80, along with built-in OS called TOS (Timex Operating System). Uses Microdrive-type syntax and can also be used to run CP/M. Other versions available from Unipolbrit and Stavi.
Source: ??
Name: FDS Executive
Manufacturer: Nordic Keyboards UK
Price: £59.95
Blurb: High quality keyboard. Full travel 51 keys with single key input for DELETE, Extended mode, full stop and comma.
Note: Nordic Keyboards were formed when Fuller ceased trading. They took over the Fuller range and extended it. Hense the use of the FDS name.
Name: Feedback Eliminating Device (FED)
Manufacturer: Brainwaves
Price: £7.50
Blurb: "This is a small switching unit connected between your computer and cassette recorder, which isolates the redundant lead when either saving or loading."
Source: Sinclair User - Feb 83
Name: Fiz Disk Interface
Manufacturer: Interactive Components Ltd.
Price: £ ?
Blurb: Interface and 5.25" drive. Little is known about this, any help appreciated.
Source: Andy Davis
Name: Force Astro Workstation
Manufactuere: Force Astro Ltd
Price: £19.95 (£45.00 with optional keyboard)
Blurb: "The new Force Astro workstation is ergonomically designed to accomodate your Spectrum, TV, recorder, PSU, Interface 1 and most other periperals, in a robust, lightweight, attractive self-contained unit." Includes reset switch. Also has space for an optional full travel keyboard.
Source: Personal Computer Games October 84
Manufacturer: David Husband
Price: £69.32
Blurb: Forth on ROM cartridge. The cartridge switches out the Spectrum BASIC ROM and replaces it with its own 12k ROM which includes FORTH, Z80 assembler and terminal software. The card also has a RS232 port (via 8251 chip), 24bit parallel (via 8255 chip).
Source: ZX Computing Dec/Jan 84
Name: Fox Programmable Joystick Interface
Manufacturer: Fox Electronics Ltd.
Price: £20.99
Blurb: Total compatibility with all games.
Name: Fox Upgrade Kit (16-48k)
Price: £21.00 (issue 2 machines only)
Blurb: High quality kit at a low price.
Name: Flight Deck Joystick
Manufacturer: EEC Ltd.
Price: £9.95
Blurb: At last, a joytisck that needs no interface. Sits on top of the Spectrum over the cursor keys. Opperates all the cursor keys.
Manufacturer: Floyd
Price: £79.95
Blurb: Printer. 32 or 40 character printing. Inverse. Double width/height. Firmware software.
Manufacturer: Monitor
Price: £12.95
Blurb: Tape transfer cartridge for Microdrive.
Manufacturer: Fuller Micro Systems
Price: £29.95
Blurb: The sound system for the Spectrum. Bult-in audio amp. Based on the G1-AY-3-8912 sound chip. Allows you to program a vast range of sounds for your Spectrum. 3 channels. Includes joystick port. Through ports.
Name: Fuller Centronics Interface
Price: £39.95
Blurb: Standard centronics printer interface.
Name: Fuller Dual Interface
Price: £49.95
Blurb: Centronics and RS232 interface in one unit.
Name: Fuller FDS Desktop System
Price: £39.95
Blurb: Elegant system designed for professional use. Includes full travel keyboard based on the FD42.
Name: Fuller FD42 Keyboard
Manufacturer: Fuller Micro Systems.
Price: £29.95
Blurb: 42 key full travel keyboard. No soldering required.
Name: Fuller Master Unit
Price: £54.95
Blurb: Contains both the Fuller Unit and Orator in the same box.
Name: Fuller Orator - Speech Synthesis
Price: £39.95
Blurb: Uses allophone system to produce speech. Based on the G1-SP0256 AL voice chip.
Name: Fuller RS232 Interface
Price: £34.95
Blurb: Rom based software.
Name: Fuller Soundstick
Price: £19.95
Blurb: Sound amplifier and standard joystick interface.
Note: When fuller went into receivership and were bought out by Nordic, this product was continued and advertised as the Nordic Soundstick. (SU Jan 85)
Name: Furguson MA20 Monitor Interface
Manufacturer: Furguson
Price: £ ?
Blurb: Interface to allow monitors to be attached to your Spectrum. (possibly only the Furguson MC01TV/Monitor) Picture adjust and sound via tv/mon.
Source: ZX Computing August 85
Postby crustyasp46 » Tue Jan 20, 2015 7:27 pm
Spectrum Hardware Index - G
Manufacturer: Marvic Merketing
Price: £9.95
Blurb: Plastic casing that fits over the Spectrum keyboard. Holes over the keys are then filled by small 'pegs' that act as keys. Using only the keys set within games, allows for more accurate key presses.
Name: Gamestar Cable Box
Manufacturer: Cable Interactive Services
Price: unknown
Blurb: Small box about the same size as a VTX, that plugs into the cable network and allows you to download software. Not much info on either the box, or the service ?? News article in Crash 4 (May 84)
Source: Crash issue 4 (May 84)
Manufacturer: Powertran Cybernetics
Price: £1750.00
Blurb: Professional hydraulic arm. 6 degrees of movement; waist, shoulder, elbow and wrist evevation, wrist roll and gripper. Uses position feedback sensors.
Source: The Home Computer Advanced Course 1984
Manufacturer: X-Trade
Price: £20.00
Blurb: This is a 4 channel, 8-bit sound board. It has its own Z80 CPU onboard, running at 10MHz and 128Kb of memory (16Kb ROM and 112Kb of RAM). Many games were converted to work with GS in Eastern Europe, using the music and sound effects from the Amiga versions.
Source: X-Trade
Name: General Sound Memory Module
Price: £12.00
Blurb: A memory module for the General Sound board. With this module installed, your GS board will have 512Kb of RAM in total.
Source: X-Trade
Manufacturer: British Micro
Price: £143.75
Blurb: Drawing into the future. Graphics pad complete with light pen and software.
Grafpad
The following advert was taken from Your Spectrum Issue 4
GRAFPAD for Sinclair Spectrum . . . Drawing into the future !
Now you too can have the benefit of drawing your own applications by the simple use of our NEW ZX Spectrum version of Grafpad.
The Grafpad comes complete with cassette programme, special keyboard overlay, plug, light pen and, of course, a comprehensive manual full of tips and instructions . . .
all at the usual high quality expected from British Micro.
Starting up is simple. Connect the Grafpad, switch on your Spectrum and connect the cassette player, type LOAD and press ENTER, then start the casette player, place the keyboard overlay and by the time you are ready, the MENU will flash on to your screen.
Uses ? well there is. . .
As many uses as you can imagine by first following our easy manual, then, in no time, you will
be able to utilise as you think best.
A unique product that will improve your skills and give you endless hours of excitement.
The following review was taken from Home Computer Advanced Course 1984
The Grafpad is a digitising tablet for producing detailed designs and drawings on a home micro. It offers a basic specification at a price low enough to attract people who would normally avoid this area because of the costs involved. There are versions available for the BBC Micro, Commodore 64 and Sinclair Spectrum.
Graphics tablets are one of the most versatile and useful peripherals for micros. They have obvious uses as drawing and design aids, from freehand art to electronic circuit design and tracing maps. But beside straight forward drawing applications, they provide a useful extra input device. A card overlay on the graphics tablet can have all of a program's features laid out, either in words or pictorially. All you do is touch the appropriate command with the stylus (pen), and the software will workout which option you have selected.
Such systems used to be the preserve of specialist machines, sold specifically for designers and engineers. But prices have fallen sufficiently to let home users try tablets out for themselves. The Grafpad examined here is one of the leading low-cost designs, bringing a good specification for a reasonable price. It's available in specific versions for the BEC Micro, Commodore 64 and Sinclair Spectrum.
There are three elements to the Grafpad: the pad itself, a linked stylus and the controlling software. The pad connects to the Spectrum via the user port and the stylus plugs in to its side. The surface of the pad is divided into a ruled grid of 16 by 20 boxes and a command bar (a separate panel with single letters inscribed on it). The
command bar can be used to control some of the software without the need to use a keyboard. On top of this slots a perspex cover to protect the surface of the pad. It is possible to design your own 'overlays' with your own commands and grids drawn on them.
Inside the pad is a grid of 320 by 256 wires approximately 1.2mm apart. The stylus nib is a tiny switch. When you push the stylus down on the perspex cover of the pad, a ULA (uncommitted logic array) chip pulses each of the wires in turn until it detects the position of the pen by a change in capacitance. This scanning takes place 2,000 times a second, making locating the stylus a very fast process. The stylus should be held by the earthed metal band around its nib to help the system work reliably.
When the stylus is placed on the pad, the computer receives the 'stylus down' signal and a report of its co-ordinates on the pad. The exact effect it creates is determined by the software. A cross-shaped cursor might appear on the screen in a corresponding position, or a particular command night be triggered. Its here that the Grafpad's economy begins to show. The stylus can only be detected on a grid of 320 by 256 positions, making it difficult to draw very smooth or fine detail. The pad is also quite small - a sheet of A4-sized paper is a sensible work area.
Note: I am unsure if the Spectrum version came with a CAD package, but I have left the text as it appeared.
The Grafpad has three software packages; ranging from a simple demonstration routine, via a simple drawing program, to a complex CAD (computer aided design) package. The simple read-the-pad routine can be incorporated in your own programs (its supplied in machine code and a BASIC version).
The drawing program is an electronic etch-a-sketch program comparable to most artist packages available, even those that don't use a pad. It offers all the basic features: lines, boxes, circles, triangles and 'freehand', and will fill an enclosed area with a particular colour. However, it lacks more sophisticated facilities, such as being able to copy and move sections of the drawing.
Certainly there is nothing here that a keyboard-only piece of software couldn't do although the Grafpad does allow designs to be traced.
The CAD program is simply a demonstration of some of the principles involved. First, you create a set of characters to be used in the construction of your designs. For electronics, these shapes might be components such as transistors, resistors and so on. You could also create logic gates, pieces of furniture, or even tile patterns. Once these are created, you move onto the actual drawing board where you can freely repeat and arrange the shapes and join them with straight lines.
This is very Similar to how a real CAD package works. But the Grafpad software isn't up to serious use. Among
the facilities you would need are the ability to label the diagrams, rotate and scale drawings, magnify a particular portion of the screen, position small shapes very accurately and so on. More flexibility in correcting mistakes is essential and in general the CAD program misses the point of using the Grafpad as an input device. Despite the small command bar on the tablet, many commands need keyboard input and overall operation is rather cumbersome.
The Grafpad itself is a versatile peripheral that offers very good value for money. In terms of area, resolution and
reliability, it is restricted in order to be economically priced. However, the software that comes with the system
is disappointing and the unit will appeal most to those who want to write their own programs. Even so, with suitable effort, tablets like these will enable people to explore new possibilities and should prove a considerable
boost for more advanced graphics on home micros.
Postby crustyasp46 » Tue Jan 20, 2015 7:31 pm
Spectrum Hardware Index - H
Name: Harris & Lockyer Keyboard
Manufacturer: Harris & Lockyer Associates
Price: £26.95
Blurb: Bare keyboard without a case. Presumabley they sit on top of the computer. Keyswicthes and a spacebar.
Source: Sinclair User Oct 82
Manufacturer: Haven Hardware
Price: £16.95
Blurb: I/O ports. 8 input and 8 outputs.
Name: Haven Keyboard Beeper
Price: £8.90
Blurb: Emits a beep when any key is pressed. {why? you can do the same with POKE 23609,x}
Source: Sinclair User Jan 83
Name: Haven Single Key Input
Price: £4.95
Blurb: Small board that is soldered inside the Speccy that eliminates the 'keyword' feature, instead giving single letter entry.
Name: Heart Rate Monitor
Manufacturer: Magenta Electronics Ltd.
Price: £29.98
Blurb: Monitor your heart rate via your finger tips. Place fingers over pads and the unit will do the rest.
Source: Sinclair User Sep 83
Name: Hilderbay Interface
Manufacturer: Helderbay Ltd
Price: £45.00
Blurb: Centronics printer interface with software. Supports all printer commands.
Source: ZX Computing Aug/Sep 83
Manufacturer: Hilderbay Ltd.
Price: £5.95 / £7.95
Blurb: Cure tape loading problems with this interface. Stop drop-outs and load even poor quality tapes. Deluxe version (£7.95) has a larger meter.
Source: Sinclair User - Mar 83
Name: Hobbyboard Intelligent Joystick Interface
Manufacturer: Hobbyboard
Price: £20.80
Blurb: Supplied in kit form, this was a standard programmable interface.
Name: Hobbyboard Micro Interface
Price: £9.50
Blurb: Hobbyboard offered build-yourself kits to produce things like light pens, digitisers and model controllers. This interface was to 'professionalise' your kits.
Manufacturer: Konami Ltd.
Price: £9.95
Blurb: Joypad with twin button. Aimed at sports sims like Hypersports it has buttons similar to the arcade machine.
Postby crustyasp46 » Tue Jan 20, 2015 7:46 pm
Spectrum Hardware Index - I
Manufacturer: Griffin Electronics
Price: £15-20 approx.
Blurb: Input/output interface with 8 analogue and 4 digital inputs and 4 digital outputs.
Source: Magnus Loutit
Name: I2L Joystick Interface
Manufacturer: Interactive Instruments Ltd.
Price: £14.95
Blurb: Standard Kempston compat. joystick interface.
Source: Home Computer Weekly August 83
Name: I2L Spectrum Sound
Price: £9.95
Blurb: Sound amp with speaker and Load/Save switch.
Name: Indescomp 32k Ram Pack
Manufacturer: Indescomp
Price: £39.95
Blurb: Upgrade 16k Speccy to 48k
Source: Your Computer June 84
Name: Indescomp Domestic Controller
Price: £49.95
Blurb: None, but I assume its an interface to control electical systems by switching the power on or off.
Name: Indescomp Joystick Interface
Price: £14.95
Info: Standard (Kempston) joystick interface.
Name: Indescomp Sound Amplifier
Price: £10.95
Blurb: None.
Manufacturer: G.A. Bobker
Price: £34.95
Blurb: Back-up interface with built in joystick port.
Manufacturer: Sinclair Research Ltd
Price: £29.95 (seperate), £49.95 (with Microdrive)
Blurb: Controls up to 7 Microdrives. Built-in RS232 interface. Network up to 64 Spectrums. This, along with the Microdrive, revolutionised the way that the Spectrum worked. For the first time, Spectrum owners could experience fast access times and super-fast loading.
Source: Sinclair User Oct 83
Sinclair Interface I + Microdrive
The following article was taken from Sinclair User - October 1983
The Microdrive with the Interface 1 module has produced the biggest improvement to the Spectrum yet. It can do eveything a disk drive can do but is much cheaper and the interface contains three modules for the price of one. The interface unit controls the Microdrive and RS232 communications/printer interface and a network which allows you to talk to another 63 Spectrum users. The unit fits underneath the Spectrum and tilts it a comfortable typing angle of 20 degrees. It is fixed in place with two screws to stop any 'wobble' that might occur. On the back of the unit are 3 sockets and a duplicate of the expansion connector, so other devices can be plugged in. The RS232 interface is a standard way of connecting printers and other devices like modems which use only one wire to pass data across. Each byte is broken into eight binary bits - see the BIN function in the Spectrum manual - and sent down one bit at a time. That method of swapping information is called serial access and is used on all the Interface 1 devices, including the Microdrive. That involves timing the length of each bit and so the speed of the RS232 can be set to match the speed of the device from which you are sending or receiving data. Speeds of up to 19,200 bits per second - the baud rate - can be set easily by POKEing a number into two new system variables listed in a new manual provided. Those system variables take up another 58 bytes after the ones listed in the original manual. Sinclair has made Basic the operating system of all the devices connected to the interface, so you will have to learn to use the channels and streams information contained in the new manual along with the various extensions to Basic provided by the new ROM.
Apart from streams, the extra commands are MOVE, ERASE, FORMAT and CAT. MOVE transfers a file of information - not a program - from one device to another. CAT provides an alphabetical list of files on a Microdrive showing their names and the amount of free space in Kilobytes. Files can be protected from CAT by including CHR$(0) as the first letter in the name. As with cassette files there is no foolproof way of protecting anything on a computer. ERASE allows you to clear out the file named on the Microdrive and FORMAT allows you to wipe a Microdrive cartridge.
The Microdrive is a very simple device. It has only two moving parts - three if you include the write-protect switch. The motor and a ratchet which stops the motor reversing are the only moving parts. The tape head is fixed and two springs either side, which bring the tape to the head and not the other way round, eliminate the need for alignment of the head. It acts like a very fast continuous loop tape recorder running past the head at 30 inches per second - 16 times as fast as a normal cassette recorder.
The tape is made of 1.9mm wide, 23 micron thick video tape, which is slightly thicker than domestic home video tape. Sinclair claims that more than 5,000 operations can be done on the tape before it wears out. The tape format is in blocks of 512k bytes called sectors and if a block is faulty it is marked so that it is not used. All cartridges have at least 85k of space but the amount varies depending on the number of sectors damaged by the manufacturing process. With up to eight Microdrives connected to one Spectrum, 860k of storage can be acheived. Cartridges are available at £4.95 each.
The following review was taken from Your Computer 1983
Sixteen months after they were announced the first Microdrives are jut being delivered, The price is still £50 for a drive which takes 85K tape cartridges instead of the l00K originally promised, but you can find and load a program in a few seconds. You will also need the Interface 1 before you can plug in up to eight Microdrives, but this interface gives you RS-232 and local area networks.
The Microdrive is housed in a box 90 by 85 by 40mm in size with an aperture at the front for loading the cartridge, and printed circuit board edge connections on both sides towards the rear. The right hand connector plugs via a flexible cable to the interface unit, if it is Microdrive 1 or plugs directly through a double ended socket to the next Microdrive. The drives are secured to each other by a plate underneath the housings. This should prevent the dreaded wobbles.
There are two small printed circuit boards inside which are without modification. The lower board provides the two edge connections, while the central vertical board houses a ROM and the tape head, which is used for both record and erase functions.
The mechanism is uncomplicated- The drive is generated by a rubber roller mounted directly on the end of the motor spindle. Pressure is applied by a leaf spring on the opposite side of the cartridge. The spring also maintains the cartridge position relative to the head, a very simple and highly efficient setup. My only worry would be head wear due to the abrasive action of the tape.
When the Microdrive is running, an LED indicator is lit. A warning is given not to remove the cartridge while this light is on
The cartridge is claimed to be able to handle up to 50 files and have a minimum storage capacity of 85K. The two spare cartridges supplied for the review both had 90K of storage space available when formatted,
Typical access was very fast in comparison with cassettes but, human nature being what it is, you tend to notice when it is slower than usual, It can take longer to type in the load command than to find and load a short file The storage media is an endless loop of tape. The cartridge is very small 45 by 35 by 7mm., including cover and makes the opposition's 75mm. floppies seem huge in comparison. The cartridge can he write-protected in a
similar manner to cassettes by removing a plastic tab, a piece of sticky tape with re-enable write.
I assume that before long we will be able to purchase S100 and S200's - Sinclair 200K -cartridges, In some
applications it is quantity of storage rather than speed of access that is important. It will also be necessary to
store the cartridges in a holder similar to those available for cassettes. The Sinclair hardware add-on industry
is in business again.
Sinclair only supplies one blank cartridge per Microdrive, further cartridges are supplied singly with an order form for repeat purchases. Bearing in mind Sinclair's advice on the need for back up copies, it just is not sufficient.
It is possible to use strings for filenames in the Microdrive commands and variables for the Microdrive number.
Because of the initial high cost of the cartridges, it makes sense to produce the tidy facility shown in Program 1.
Program 2 was used to test the file storage capacity of 50 files. Three points emerged from the tests:
1) Each file appears to occupy a minimum block of 512 bytes.
2) As the limit of 50 files is exceeded, file names disappear from the catalogue in an apparently random fashion,
but they still occupy space on the cartridge and are still loadable.
3) The average time taken to Save a short file in this manner is 10 seconds.
An attached Microdrive has no effect on the vast majority of commercial software. Only in one case where a
program used interrupt control was a program found not to work, and I am not sure why not. If you open a stream to the Microdrive or Net then problems will arise, but if you do not try to use the Microdrive or try to Network a program then it should make no difference whatsoever. The user is warned not to remove a cartridge while the Microdrive's LED is lit and not to switch on or off with a cartridge in the drive. This I continually forgot with no apparent mishaps to the stored data.
I think the user would be wise not to leave a cartridge in the drive for long periods of storage, the pressure roller
may take a permanent set and upset the tape transport. I would have liked a protective flap over the cartridge
entrance, not all drives will be used in a clean environment.
The ZX Interface 1 was also announced in April 1982. It was simply called the RS 232/Network interface board
and was expected to sell for £20. Since then it has been expanded and now serves three functions:
>Microdrive controller
>RS232 interface
>Local-area network
This little box of goodies is something special. There are flaws but it is still a very powerful addition to the Sinclair range of computer peripherals.
Surprisingly the two printed circuit boards in the Microdrive show no signs of modification whereas the printed
circuit board in the interface has been altered. The board contains two integrated circuits, a prototype Ferranti
LSI and an EPROM.
A Sinclair spokesperson has stated that the equipment delivered to customers will, in fact, contain proper
production devices.
The interface plugs into the Spectrum rear connector and is attached through two existing screw holes to the
underside of the Spectrum, the original screws may be discarded. A duplicate rear connector port is available
on the interface as are the two 3.5mm, network sockets and the nine-pin d-shell connector for the RS-232
printer/peripheral interface.
The Microdrive plugs into the exposed printed circuit board edge connector at the side through a flexible cable.
The whole assembly is rigid and now the keyboard has been tilted, feels much easier to use.
The interface unit acting as the Microdrive controller, expands Sinclair Basic to include elementary file handling
and communications commands.
The commands are created by paging the 'new’ RQM which creates an additional set of system variables. It
looks from an cursory glance, that it is possible to re-vector the input - output routines used in both the
Microdrive and Network channels.
The commands become a bit of a chore to handle after a while and you are soon driven to looking at
producing your own simple operating systems.
The RS232 interface, which operates over a range of 5O to 19.2K baud with no parity, 8-bit character and two
stop bits, should cover just about all but split-speed operation There are two modes of operation.
The t channel is normally used for listings, the control codes are not sent except for 13 -carriage return - and
the token codes are expanded. There is no graphic capability. These characters are replaced by code 63 (?).
The b channel sends the full 8 bit code and is used to send control codes to printers etc.
I can not recall ever having said that something from Sinclair was expensive, but £15 for an interface lead is a
bit steep.
The ZX Net - local area network -promises to be a very powerful tool. The network is set up by simply joining
two Spectrum interfaces together with the 10ft. long net lead. The manual reveals a network operating at l00K
baud with handshaking between two attached devices. Up to 64 Spectrums can go on the net.
Print station facility
There is also a broadcast facility to download information to anybody listening on the net. This would permit a
teacher to broadcast a program to the whole class at once.
Other uses include the ability to set up a print station to service all the Spectrums on the net. Perhaps when
Sinclair has managed to clone a few interfaces these properties can be evaluated.
The manual falls short of the usual high Sinclair standard due, in part, to the fact that it is not a derivative of an
earlier work. Everything appears to be there but I think some of the text needs presenting in a much simpler form.
The demo tape contains a print server program, untested, and a poor-man's Horizons tape-a-data base-program
which provides the meaning of the Microdrive commands from a database at what can only be described as
slow, I was not impressed.
PROGRAM 1
10 DATA ":REM files for deletion
20 DATA ‘zxc’
30 RESTORE
40 READ a$: IF a$ = ‘zxc’ THEN GOTO 70
50 ERASE ‘m’;1;a$
60 GOTO 40
70 CAT #3;1: STOP
PROGRAM 2
10 LET a$=’Kate’
20 LET d = 49
30 LET b$ = a$: LET a$ = a$ + CHR$ (d)
40 SAVE *’m’;1;a$
50 LET a$ = b$
60 LET d = d + 1
70 IF d = 11- THEN CAT #3;1: STOP
80 GOTO 30
Price: £19.05
Blurb: Rom cartridge interface with twin joystick ports. Sinclair's second interface did not take off like the first one. This ROM interface was produced to try and keep up with the consoles. Instant loading ROM cartridges were produced for the interface, liecenced by Sinclair. Only 10 titles were available (to my knowledge), they were; Planetoids(Psion), Space Raiders(Psion), Backgammon(Psion), Pssst(Ultimate), Cookie(Ultimate), Jetpac(Ultimate), Transam(Ultimate),Hungry Horrace(Melbourne House), Horrace & The Spiders(Melbourne House), Chess(Psion).
Source: Sinclair User Dec 83
Sinclair Interface II
The following articles were taken from Sinclair User - December 1983
NEWS
Hard on the heels of the Microdrive, Sinclair Research launched its interface 2 at the end of September. Billed as a peripheral for beginners and experts, it costs £19.95 and allows Spectrum owners to load cartridge software and use any joystick with a nine way D plug. At £14.95, the cartridges are not cheap but Sinclair Research claims they are fast and easy to load. Because the whole program is stored on the cartridge, leaving the computer RAM unused, any program will run on a 16k machine even if it was written originally for 48k.
The cartridges already available include games like Space Raiders, Cookie, Hungry Horace and Jetpac, as well as Chess and Backgammon. True to form, Sinclair Research is offering the Interface 2 for sale by mail order only in the early stages. "The response has been good so far," says a company spokesman, "but it is too early
to say how sales will develop. We cannot predict when Interface 2 will be available in the shops."
REVIEW
Sinclair has just announced the Interface 2, which has followed the Interface 1 within a few weeks.Interface 2 provides two joystick sockets, which take standard Atari joysticks and a ROM cartridge slot. The joystick ports are non-standard, as the only software to work with them is from Sinclair or Psion.
They operate the number keys only and each joystick operates the first or last set of numbers. Despite the advertisements there is no software built into Interface 2 - only a ULA to act as a port for the joysticks. The ROM cartridge socket is also a disappointment, as it provides no special switching to page ROM's in and out. The cartridge has all 16 address lines and eight data lines on it but, because of the way Sinclair designed the Spectrum, none of the internal memory can be switched off, so the only programs which can be provided can be 16k long versions which will replace the Basic ROM.
They are available by turning-off the power, plugging in the cartridge and turning on the power. The games then auto-start. An interesting point is that Sinclair has saved money by having the bare silicon chip wired direct to the PCB instead of mounting inside the normal IC casing. A printer connection is provided at the back of the unit to run the Sinclair printer only. That is because none of the other connections is connected. It would seem that Sinclair has produced its last peripheral for the Spectrum.
At £19.9 for Interface 2 and £14.95 for each ROM cartridge, they may not be in great demand unnless the price is reduced dramatically. The joysticksare also out of step with software manufacturers who program games to work with the Kempston-type joystick interfaces. Sinclair Research is the only company selling Interface 2.
The following review was taken from Personel Computer News October 1983
Plug in and go . . .
Instantaneous loadings now a reality for Spectrum owners, with the release of Interface 2, which provides a joystick interface and ROM cartridge port for the machine.
Its arrival comes as something of a surprise - it was launched quietly in late September, bang on schedule, and users waiting for the Microdrives, courtesy of Interface 1 are currently being invited to buy Interface 2 before they've even had so much as a sniff of Interface 1.
Stocks of the new interface are apparently large enough for it to be readily available, although Microdrives are still in very short supply.
Interface 2 plugs neatly into the back of the Spectrum - or, for the lucky few, into the back of Interface 1 - and provides two major advantages for the machine. First, ROM cartridges can be used, so all you need do is power up for your program to be ready and loaded, and second, it will accept two standard Atari-type D-plug joysticks.
Sinclair Research emphasises that these can be any type of joystick with a 9-way D-plug, and that, as the necessary software is built into Interface 2, the joysticks will work with cassette-loaded programs as well as ROM cartridges. Ten of the most popular Spectrum games are already available on cartridge.
Interface 2 is currently being sold by mail order for £19.95, and the ROM cartridges are selling for £14.95 - cheap for what they are, but still something of a blow for those used to cheap games tapes.
The Spectrum was initially conceived by Sinclair as a low-cost hobbyists micro - it did the job it set out to do well, at a very competitive price. But it was still something of a bare bones machine - many of the facilities needed to communicate adequately with the outside world were left out of the design. Users were therefore left with just the cassette interface, and with a cheap, but poor quality, printer.
Bit by bit, companies like Kempston filled the gap - it became possible to use joysticks and decent printers, although there were still compatibility problems. Not all games would operate with a given joystick. and vice versa. Therefore, although some excellent games have been produced for the Spectrum, it hasn't always been possible to play them the way they should be played. And if you were reduced to playing through the keyboard alone, you'd have even more problems because of the poor response from the cut-price keys.
Construction
With Interface 2, these problems are starting to fade. The device itself is finished in the standard Sinclair Model T black, is slightly wider than the Spectrum's edge connector, and slots tidily into said connector. The ROM cartridge itself slots into a slightly oval socket, which is protected by a sort of hatch affair, and the joystick ports are situated to the left of this.
It is a prime example of the growing petite-ness of Sinclair Research products.
But in operation, it's more than just a pretty case. Setting aside for the moment the ROM cartridge facility, which will allow you to load programs which would otherwise be simply too big for the Spectrum, the joystick interface alone promises to give the market a thorough shaking up, for a number of reasons.
First, there is the advantage of standardisation. The Kempston set-up had already gone some way to achieving this, like Interface 2, the Kempston interface plugs into the edge connector, and uses standard D-plug joysticks. and the com-pany has been having some considerable success in persuading software producers to include joystick code routines in their games programs.
But this has in no way been a universal solution to the problem. Many of the Spectrum owners most willing to spend money on a joystick interface must already be confirmed games addicts, and so will have at least a handful of games which were, until now, incompatible with joysticks of any description.
You could use the Pickard Joystick Controller, which is wired up in such a way that it fools the computer into thinking that you are sending it the key codes it expects, but it is a fiddly operation to fit, and is not particularly warranty-friendly.
Interface 2 gets round this rather stylishly, and simply because it comes from the machine's manufacturer, it is assured of the position of the industry standard.
Sinclair hasn't made the support bracket, featured on the Interface I part of the package. This bracket screws on to both the Spectrum case and interface 1 to form a solid connection with the Spectrum board and reduces the dreaded RAM-wobble problem prevalent on the ZX81.
The connection has a tendency to wear down leading to frequent crashes and the omission here is particularly unfortunate considering the unavoidable amount of stress and strain likely to be placed on the Interface 2 as cartridges and joysticks are plugged in and out.
Visually, the nicest thing about the product is the cartridge itself. True to form, Sinclair has done a marvellous miniaturisation job, producing cartridges about 1.5 x 2 x 0.3 inches.
At £14.95 Sinclair is producing some of the cheapest games cartridges on the market although they now look decidedly overpriced following Commodore's recent decision to cut its games cartridges for the Vic 20 to around the £10 mark. There was some talk from Sinclair before the launch to the effect that £16 would be the price for its cartridges although it may be that the price will come down after a few months.
Another nifty feature is the red rubber skirt which envelops and protects the cartridge connector when it is not plugged into the games port. When the cartridge is plugged in, the skirt is pulled up out of the way.
There's a hinged lid over the games port and a pair of plastic plugs to protect the joystick sockets. These are easily remov-able - and also easy to lose, although Sinclair says they can be dispensed with anyway.
In use
As with all cartridge systems the power must be off when the cartridge is inserted or removed from the port. On the Atari this restriction is made idiot-proof by the access lid to the cartridge cavity switching off the power to the computer when it is opened.
Unfortunately no such safeguards are featured with Interface 2, though the law of probability says you will commit this crime at least once during the lifetime of the system.
The accompanying literature is sketchy but adequate, telling you how to program the joysticks for you own games in Basic or machine Code.
The codes follow the top row of the keyboard: ten keys equal up, down, left, right and fire for each of two joysticks and these can be read from Basic using the IN function.
All the cartridges can be used with either a 16K or 48K Spectrum because your not using much of the RAM memory in any case. You can use the interface and joysticks with cassette games as well and, according to Sinclair the games produced over the past year already have the routines for joystick control included.
Sinclair wont commit itself to when the interface and cartridges will make an appearance in the shops alongside the cassette tapes. It will depend on demaid which so far has been encouraging.
Verdict
The Interface 2 is a neat little product. Its priced about right and Sinclair obviously hopes to make a big killing in the run-up to Christmas. It would be a much better product if the cartridges were priced at £10 instead of £15.
"According to Sinclair the number of games cartridges will increase quickly. It's likely that the introduction of the Interface split the Spectrum market up into two distinct segments - serious applications for Interface 1 and Microdrive owners and games for the Interface 2 users. In the mean time its likely that cassette games will serve as a test market for the cartridges - the best selling games will obviously be 'moved across' first.
At the moment there are ten games available on cartridge. These are Space Raiders, Planetoids, Hungry Horace, Horace and the Spiders, Chess, Backgam-mon. Psst, Jet Pac, Cookie and Tranz Am."
Price: £39.95
Blurb: Transfers every program to microdrive. Snapshot anything in memory and dump to drive.
Source: ZX Computing Aug/Sep 85
Manufacturer: DCP Microdevelopments
Price: £39.95
Blurb: Multi port exspansion. Includes; 8bit TTL input, 8bit TTL output, 8 channel digital/analogue converter.
Manufacturer: Bud Computers Ltd.
Price: £11.95
Blurb: Joystick interface that supports the IN 31 command as used by Kempston. Also includes rapid fire and reset switch.
Source: Sinclair User Jan 85
Price: £22.95
Blurb: Programmable joystick interface. Allows the unit to 'remember' settings via onboard 1k Ram. Also includes reset switch.
Re: Spectrum Hardware Index
Postby crustyasp46 » Tue Jan 20, 2015 7:49 pm
Spectrum Hardware Index - J
Manufacturer: J. English Electronics
Price: £17.99
Blurb: Touch sensitive joystick. Solid state switching.
Source: Your Sinclair Feb 86
Name: Jiles III Joystick Interface
Price: £13.95
Blurb: Supports Kempston, Cursor and Psion via moveable peg.
Name: Joystick Interface [color=#00FF00](no offical name)[/color]
Manufacturer: Interceptor Micros
Price: £15.95
Blurb: Allows standard Atari type joystick to be used.
Price: £15.95
Blurb: Joystick interface with twin connectors. Controlled by software using the IN command.
Source: Sinclair User March 83
Name: JRS Programmable Joystick Interface
Manufacturer: JRS Software
Price: £22.50
Blurb: Use your joystick with all your favourite software.
Users browsing this forum: No registered users and 92 guests
