tapDancer Android .TAP player
Postby kicaco » Sun May 05, 2013 10:18 am
Got a C64? Check out our new free Android application, tapDancer.
tapDancer converts .TAP to wave, then plays the file through your Android device -- which, if connected to a CD to cassette converter inserted into your Datasette, allows you to load the .TAP on your C64 (C128, VIC20, etc.)
We've tested it with a number of different loader formats, including the infamous Novaload.
You can get it free from the Google Play store. Tell us what you think of it!
kicaco
Fav System: C64
Re: tapDancer Android .TAP player
Postby kicaco » Sat Jun 29, 2013 12:13 pm
Version 1.5 has been released (but may take a few hours to entirely propagate through Google Play):
* Added support for additional Commodore formats (T64 / PRG), Acorn Electron / BBC (UEF), MSX (CAS) and Atari (CAS - *Experimental*).
* Added auto-pausing functionality (available in Settings menu.)
* Added TurboTape compression support for T64 and PRG formats (3 compression levels.)
* Improved reliability of playback on Jellybean devices (re-worked the playback engine.)
* Support for alternate storage locations (such as internal storage.)
Note: All existing caches will need to be re-rendered.
https://play.google.com/store/apps/details?id=co.kica.tapdancer
kicaco
Fav System: C64
Users browsing this forum: No registered users and 95 guests
