Macintosh ROM Secrets
Postby crustyasp46 » Sat Sep 29, 2012 2:54 pm
Subj: clearing things up... (50/50)
Date: Fri, Nov 23, 1990 2:36:06 AM
1) THE SE ROM SLIDESHOW
In the ROM of the original Macintosh SE (*not* the SE/30!) is a four-frame
slideshow composed of digitized b&w images of the development team.
To view the slideshow, hit the interrupt switch to enter the debugger,
and type the following: G 41D89A <return>.
Alternatively, you can write a program which calls this procedure:
PROCEDURE DoIt;
Inline $4EF9, $0041, $D89A; { jmp $41D89A }
The slideshow is an endless loop; once started, the only way to quit
is by rebooting (or turning the power off).
2) THE "STOLEN FROM APPLE COMPUTER" ICON
This icon lurks in the ROM of *every* Macintosh produced. Rumor has it
that code to display this icon also exists in ROM, so that an Apple
employee/wizard could walk up to a potential Macintosh clone, type a few
commands, and verify that the machine's ROM was in fact "stolen".
This icon exists at different locations in different versions of ROM;
currently, yours truly has only been able to verify its existence in
two of those versions:
ROM Version 117, rev.1-3 (Macintosh Plus): $0040E132
ROM Version 120, rev. 3 (Macintosh IIx, IIcx, SE/30): $408A065A
If you have access to other machines, you can use the Graphic memory display
feature of SUM II Tools 2.0 to locate the icon. (Be sure to set the memory
base to $40800000, the starting address of ROM on the Mac II series, or
$00400000 on a Mac Plus or earlier machine.)
It's reasonable simple to write a program that displays the "stolen icon".
Here's a THINK C function that does the job:
PlotStolenIcon(inRect)
Rect *inRect;
asm {
BRA.S @2
@1 DC.L 0x40E132 ;address of icon (Mac Plus ROM only!)
@2 MOVE.L inRect,-(SP) ;push rect argument
PEA @1 ;push "handle" to icon
DC.W 0xA94B ;_PlotIcon
3) HIDDEN COLOR PICTURES IN THE IIci AND IIfx
The 512K ROM (also known as the first "32-Bit Clean" ROM) introduced with
the Macintosh IIci evidently had some extra room for fun.
On the IIci, do the following:
A) Go into the Control Panel and set the date to Sept. 20, 1989
(9/20/89 -- this just happens to be the machine's release date.)
B) Reboot and hold down cmd-option-c-i (yes, all 4 keys simultaneously.)
C) Surprise! Up pops a color picture of some Apple employees!
On the IIfx, the procedure is similar:
A) Set the date to March 19, 1990 (3/19/90 -- the release date.)
B) Reboot while holding down cmd-option-f-x.
C) Yes, it's another color picture!
4) HIDDEN STARTUP DISK IN CLASSIC ROM
The Macintosh Classic has an "undocumented feature": a complete, bootable
system "disk" in ROM. This was an experiment in creating a "diskless
workstation" machine that apparently wasn't considered important enough
to mention as a feature. Rumor has it that the Macintosh LC and IIsi also
contain a hidden ROM disk, but this has not yet been verified.
To access the hidden disk, reboot the Macintosh Classic while holding
down cmd-option-x-o. When the Finder comes up, the ROM disk should appear
on the desktop. Note that you can use the Startup Device cdev to specify
this disk as the startup device; subsequently, the machine will boot from
ROM without the need for a "real" startup disk (handy, if you've only got
one floppy disk drive.)
Re: Macintosh ROM Secrets
Postby Dragon Mech » Sun Sep 30, 2012 9:10 am
i can confirm the the ROM boot disk for the Mac Classic does exist and works. it is System 6.0.3.
Users browsing this forum: No registered users and 130 guests
