The different Atari models
Postby crustyasp46 » Tue Mar 15, 2011 7:06 pm
would anyone have an idea how the different models of Atari are different in their programs from one to the other? eg: programming from a 130XE to programming for a 800XL to a 600XL, or are they pretty much compatible?
I know the game cartridges are not interchangeable in some cases from model to model.So is it the same with the programs? :thankyou:
Re: The different Atari models
Postby Hot Trout » Tue Mar 15, 2011 8:00 pm
On the whole they are compatable but the XL had additional hardware that could be used within the program and if it was then this made the software hardware specific.
http://faqs.cs.uu.nl/na-dir/atari-8-bit/faq.html
This will provide you with more than enough reading material.
Postby crustyasp46 » Tue Mar 15, 2011 9:29 pm
This is unbelievably funny, after posting the question, I did a search, and I was on the web site you have suggested :freakout: , So i guess Holmes we can say "solved" on this post.
Thanks HT, I appreciate the help. :thankyou:
Users browsing this forum: No registered users and 88 guests
