Mame4all IPad 3rd generation fix romset?
Having problems using roms with your iOS device like iPhone, iPod or iPad then post your questions here.
Postby water » Mon Feb 04, 2013 5:02 am
Hello guys. I don't know if this is the right place to post this question. But I being reading and had spent plenty of time trying to fix some romset to work with mame4all on my iPad 3rd generation. I ahd downloaded couple of roms from this site. But some of them don't work. For example MK3 and some other roms that are ready for mame 0.37b5 which are the roms mame4all support.
I tried to fix it using clrmamepro but I don't know how to use clrmamepro. Can somebody help me? I have couple of roms I want to be able to play on my iPad
Thanks
water
Re: Mame4all IPad 3rd generation fix romset?
Postby TERMlNATOR » Thu May 16, 2013 3:04 pm
Well, I use MAME4iOS, and i got MK3 running flawlessly on my iPhone 5. I use the 0.139ul romset. Don't know what phone you're using, but if its am iPhone use what I'm using... Or if you have an android, use MAME4Droid and use 0.139ul (MK3.zip)
Custom built PC "Skynet"
OS: Windows XP (SP3)
Mainboard: Asus M4N68T-M LE
TERMlNATOR
Been thanked: 11 times
Return to Support for iOS : iPhone, iPod, iPad
