New Ipad Emulators?
Having problems using roms with your iOS device like iPhone, iPod or iPad then post your questions here.
New Ipad Emulators?
Postby zimsjim » Mon May 14, 2012 3:42 pm
So I'm very remedial on emulators, etc..... But I got the new Ipad and was trying to figure out where or how i can do any NES, SNES, etc emulators for it?
Any detailed help would be great
thank you
zimsjim
Re: New Ipad Emulators?
Postby Hot Trout » Mon May 14, 2012 5:39 pm
Native emulators are all commercial and can be bought through the Apple app store. If you really want to start using it as an emulator you will need to jail break it first. If you search the forums you will find some help and guides on such things.
I hope this helps a little. Some of the other members on here know more about this and I would ask them to also comment.
Postby PMJPlay » Tue May 15, 2012 2:30 am
If its a iPad 3 I dont think you will get very far but if its a iPad 2 I think they just recently Jailbroken it :P
I recommend going to this site -
http://www.modmyi.com
It has a Jailbreaking Assistant to help you out at the top of the main page :P
I just wanted to let you know I used this to jailbreak my iPod Touch (2nd Gen)
http://greenpois0n.com/
Hope this help!
Postby zimsjim » Tue May 15, 2012 2:48 pm
yeah IPad 3.... anyone?
zimsjim
Postby PMJPlay » Wed May 16, 2012 7:54 am
Just find out what version of iOS you have and check out this site
http://www.spiritjb.org/
I am sure someone has jailbroken it by now.
Let me know how it goes :P
I think your best bet is using redsn0w and maybe even downgrading your current iOS :P
Postby GAMESHARQ » Fri Jun 29, 2012 6:47 pm
I don't know if you found an answer already, but if not, these might help:
http://www.ipadforums.net/ipad-hacking/ ... hread.html
http://www.ipadforums.net/jailbreaking- ... 2-0-a.html
GAMESHARQ
Postby olDirtyHelmet » Sun Aug 19, 2012 12:34 pm
hey so did you get this working?
if you still want to know there are genesis, snes, gameboy & MAME emulators for ipad/iphone which i have personally had working.. and i know there are more such as Playstation 1 & N64 but i havent had those running myself... yet
If you still need help with the mame or snes give me a shout but they're pretty straightforward once you';re jailbruck ;)
olDirtyHelmet
Next LVL Up at : 25
Next LVL Up at : 25
Has thanked: 6 times
Been thanked: 17 times
Fav System: Acorn Electron - NEO GEO
Return to Support for iOS : iPhone, iPod, iPad
Users browsing this forum: No registered users and 24 guests
