Imame4all not reading roms
Having problems using roms with your iOS device like iPhone, iPod or iPad then post your questions here.
Postby seijai » Wed Feb 01, 2012 2:20 pm
I have an ipad with FW 4.3.3
I went to Cydia and installed imame4all 1.10-1 from Big Boss
I then added ihacksrepo and installed the mame rom pack with 312 roms
Rebooted ipad and went to mame4all
It says there are no games/roms
I used iexplorer and connected ipad.....the roms are in the right directory
Any help is much apreciated
I copied the roms into my Sangsung S2 and all works there.....
seijai
Re: Imame4all not reading roms
Postby Kherr » Wed Feb 01, 2012 6:17 pm
I wish I could help you, but alas I do not own any apple products... I just have a lowly Zune. Hopefully someone will see your plea for help and get back to you as soon as possible. :hi:
Postby daffy2 » Wed Feb 01, 2012 9:54 pm
Just to confirm, your roms are in the following folder?
/var/mobile/Media/ROMs/iMAME4all/roms
daffy2
Been thanked: 52 times
Postby seijai » Wed Feb 01, 2012 11:49 pm
Yes, when I installed the Rom pack from ihacksrepo, it automatically installed it to that directory.
I checked with iexplorer and all the zip files are there.
However, when I go to imame4all on ipad, it says no games are found on the list.
I have tried uninstalling and reinstalling to no success.
Is there a problem with the imame4all program from BigBoss?
Can anyone help me?
seijai
Postby daffy2 » Thu Feb 02, 2012 2:47 pm
That's weird. I have not heard of any issues with the downloads from bigboss, and the install is easy. It should work as you've got it set up! Let's hope that someone who has experienced this and solved it will chime in.
daffy2
Postby seijai » Fri Feb 03, 2012 6:34 am
Not to worry
I took the plunge and updated to FW 5.0.1 and applied redsnow.
Reinstalled everything and all is good. Thanks for your time
seijai
Postby AirG » Thu Feb 09, 2012 2:46 am
Yea I was gonna say it works fine on 5.0.1... The hard part is find working roms!
AirG
Fav System: Dreamcast
Postby Hot Trout » Thu Feb 09, 2012 10:24 am
Are you using the 0.37b rom set? you should find most of that set will work
Postby daffy2 » Thu Feb 09, 2012 6:44 pm
:goodpost:
If you make sure that the roms you use are for the version of Mame that you have you will be rewarded! Mame is picky like that, and one of THE BEST things about The Old Computer is that the roms are broken down by version. As HT points out the Mame4All emulator in all flavors uses the 0.37b romset, so this is the one you'll want to look for in the roms section.
daffy2
Return to Support for iOS : iPhone, iPod, iPad
Users browsing this forum: No registered users and 24 guests
