need help placing ROMs on iPod
Having problems using roms with your iOS device like iPhone, iPod or iPad then post your questions here.
Postby The Shadow Dragon » Sat Apr 10, 2010 12:02 am
I need a program to access the files on my iPod touch, to place NES and gameboy roms on it. It is 1st gen 16GB running jailbroken 2.1 firmware. I also would love to know a cydia source that has SNES and genesis emulators. Thanks, TSD.
Steam: PirateBear
The Shadow Dragon
Has thanked: 9 times
Been thanked: 15 times
Fav System: Dreamcast
Re: need help placing ROMs on iPod
Postby Hot Trout » Sat Apr 10, 2010 8:46 am
I would love someone to make a detailed post for the user on this very subject. For now you should watch these videos. Do you recgonise the wbsite 8-)
There are lots more on youtube
Postby The Shadow Dragon » Mon Apr 12, 2010 7:39 pm
Thanks for that, it helped quite a bit.
Steam: PirateBear
The Shadow Dragon
Postby Guest » Mon Apr 12, 2010 7:46 pm
Though I know a bit more cause I went through this situation at one point, I am short on time.
If your looking for a program to access the files on your ipod than Google something called iPod tunnel Suite.
It lets you access your ipod through your usb cable instead of using wifi which, for me at the time, was needed.
Postby The Shadow Dragon » Fri Apr 16, 2010 3:12 am
Thank you all for the help I really appreciate it, I can finally have SMW come with me. I ended up using diskAid, a program that lets you simply transfer files to your device.
Steam: PirateBear
The Shadow Dragon
Postby Guest » Fri Apr 16, 2010 6:41 am
Glad we could help. Im gonna check out diskAid here in a min. Maybe I can find it useful too
Postby gamfrkI » Tue May 25, 2010 1:37 am
iPhone explorer
Postby JAHGoVeg » Tue Jun 15, 2010 8:53 pm
I actually use iphone explorer
http://www.macroplant.com/iphoneexplorer/
(maybe we should make a new thread of different iPhone exploring tools. :p) lol
Return to Support for iOS : iPhone, iPod, iPad
Users browsing this forum: No registered users and 23 guests
