Wanting to Upgrade my MAME
Postby Rotgut » Wed Dec 02, 2015 5:01 pm
Hey, hope all is well everyone! Thanks for all you do, Boss!
So I have a couple of quick questions. I have been running MAME v.0.128 for nearly 5 years and would like to do a re-install using a much newer version. Someone suggested v.0.167 ? What do you recommend? I want to be able to start taking advantage of all the HLSL stuff.
Secondly, when I go to your Roms section for MAME, is there a "Full Set" of roms that will run on v.0.167 ? I'm confused as to what roms I should be downloading for a specific version of MAME. I'm trying to avoid an eternal easter egg hunt, so I'd prefer a full set? I am extremely lost, I'm not going to lie.
Thanks in advance :)
Rotgut
Next LVL Up at : 25
Next LVL Up at : 25
Has thanked: 4 times
Been thanked: 5 times
Fav System: MAME
Re: Wanting to Upgrade my MAME
Postby Rotgut » Wed Dec 02, 2015 5:27 pm
I should provide some info, sorry.
I am currently running Win7 / 64bit AMD eMachines 2.7 GHz / GeForce Nvidia GTX 750 Ti 2 GB
Rotgut
Next LVL Up at : 25
Next LVL Up at : 25
Fav System: MAME
Postby lordkaosny » Fri Dec 04, 2015 5:52 pm
Hello,
My question is very similar. I've been running a version of MAME32 on a dual-core Windows XP machine for at least 7 years and am finally ready to make the jump to a modern PC. I'm going to build one based on an i5 or i7 CPU, 8GB of RAM, 4TB of storage and a dedicated video card. I suspect this rig will run most of the available ROMs at a playable speed.
Since I'm basically starting over, what's the best way to obtain the latest/greatest working ROM set? Do I have to start with a "base" ROM set and then download ROM set updates until I'm current?
Thanks,
LKNY
lordkaosny
Steam ID: http://steamcommunity.com/id/
http://steamcommunity.com/id/" target="_new"> http://steamcommunity.com/id/.png" border=0 width=160 height=45>
Postby Hot Trout » Sat Dec 05, 2015 6:54 pm
Please visit this topic, it is essentially the same question.
viewtopic.php?f=9&t=4874&p=23190#p23190
