How to get function keys to work?
Postby gee » Wed Jun 17, 2015 12:23 pm
Hi, first of all I want to say thanks for a wonderful website.
I have recently downloaded vice for my mac, but I am having trouble getting the function keys to work. I have searched this forum and elsewhere on the net but I have had no luck.
It would be good to know because some games require me to press F1 to play.
Thanks ;)
gee
Been thanked: 5 times
Fav System: Atari 2600
Re: How to get function keys to work?
Postby Dragon Mech » Thu Jun 18, 2015 8:36 am
i have never used vice for Mac. but if it is similar to WinVice, this may help. [Note: All screenshots are of WinVice (x64.exe) running on Windows 7.]
First, go to the "Settings" menu and selet the "Keyboard settings" option.
Next, select the "Positional" key settings.
The text box next to the checkbox should read something like, "mac.pos.vkm" or somthing close to that.
i hope this helps. :bowser:
Postby gee » Fri Jun 19, 2015 12:50 am
Thanks Dragon, I tried it on xvic but did not work unfortuneatly. :(
Loaded Blitz and it says press 'F1' to play but i can't :(
Enjoying Rockman though :)
gee
Postby gee » Fri Jun 19, 2015 1:33 am
Hey i just worked it out by luck.
Go to System Preferences
Select Keyboard
Select Keyboard again
Tick Use all F1, F2, etc
It works fine now :)
gee
Postby Dragon Mech » Fri Jun 19, 2015 7:08 am
that's great news gee! thanks for leting us know that you figured it out. :C64:
