HELP: Playing MAME APP via N64? Is it what I think it is?
Postby unseenforces » Fri Feb 21, 2014 10:26 pm
Hey guys... need some advice/help here :)
so I bought this N64 Flash Cart board... and for those who don't know, it's a board that you basically can put inside of an N64 Cartridge and the board has an SD slot so you can place a memory card into the board full of N64 ROMS and then play directly through your N64 all the ROMS you'd like. COOL! (These are called Flash Carts, they also make them for NES, SNES and others, learn more here:
 http://www.stoneagegamer.com/flash-carts/)
My N64 board has not yet come in.. but I'm wondering something...
Here on the old computer, under the "applications" section of N64 Roms there is an app called "MAME". (See here and scroll down: http://www.theoldcomputer.com/roms/inde ... plications)
Is this what I think it is? In theory, is this app for loading MAME onto an N64? And if that's the case, does this mean I can play MAME games on my N64 via pointing to a directory/folder full of MAME ROMS on my SD card?
If anyone has any experience or knowledge or predictions of what this MAME app for N64 is... would be REALLY appreciated.
Thanks guys!
Kind regards,
UNSEEN
Stop all the downloading.
unseenforces
Fav System: NES, SNES, N64, MAME
Re: HELP: Playing MAME APP via N64? Is it what I think it is
Postby unseenforces » Sun Feb 23, 2014 5:41 am
nobody?
I'll have to continue to wonder what my answer for a self contained mini-console-esque system running MAME roms with controllers will be.....
unseenforces
Postby Hot Trout » Tue Feb 25, 2014 8:01 pm
unseenforces wrote:nobody?
That is indeed Mame for the N64 but I have never used it so cant offer any advice other than if you get it working, i would imagine it will need an old mame set like 0.36.
BTW i love you 'Gi Joe referenced' signature. I love those paritys.
