PS1 emulator help
PS1 emulator help
Postby darren77 » Sun Nov 18, 2012 1:19 am
hello, I had a problem using the PS1 emulator Epsxe100. I can open the emulator but I can't open a ROM file. If anyone is using this emulator could you give me a quick step-by-step on how to play a PS1 game? Maybe then I can see what I'm doing wrong.
Any help would be most appreciated, thanks!
darren77
Next LVL Up at : 15
Next LVL Up at : 15
Has thanked: 4 times
Fav System: NES
Re: PS1 emulator help
Postby PMJPlay » Sun Nov 18, 2012 5:50 am
I recommend you download pSX 1.13 and get PSX roms off the site here they are zipped and contain a .bin file and .cue file. You can load them by loading the .bin file. :D You dont need plugins with pSX :D
Postby Kherr » Mon Dec 10, 2012 9:14 pm
ePSXe 1.8 just came out not too recently and the Pete's plugin pack is a great set of plugins needed to use ePSXe 1.8. I love ePSXe 1.8 and don't plan on using any other emulator anytime soon. :3
Postby SE7EN » Mon Dec 10, 2012 11:51 pm
with epsxe, you should be able to navigate to the (uncompressed) folder (meaning not .zip'ed or .rar'ed, normal NTFS file compression may/may not be ok) and it should only display the files it can open. if there are 2 of the same name, I think it is most likely to be the larger of the 2. Just go to file>run iso (or something similar to that) and if you store all your .isos and .bin .cue and .img .ccd files in the same folder it will save you some time, as it will remember the last directory used, so you won't have to change folders for the next game you run.
Postby darren77 » Fri Dec 14, 2012 10:41 pm
Hi- Thanks for your posts. Unfortuately, I haven't quite got it yet. I downloaded epsxe, but was unable to open the game.
Let me try starting over, from zero! Could someone give me a quick step-by-step so I can see where I messed up?? Also, I assume that I need 7-zip correct?? I'm using windows. Again, many thanks - I want to give this another try, I just need a few specifics along the way.
darren77
Next LVL Up at : 15
Next LVL Up at : 15
Fav System: NES
Postby SE7EN » Sat Dec 15, 2012 12:21 am
http://www.fantasyanime.com/emuhelp/emuhelp_epsxe.htm
first result on Google 'epsxe guide' and seems to be pretty in depth.
Postby darren77 » Wed Dec 26, 2012 11:14 pm
A two part follow-up question: because I haven't tried it yet......if I have the emulator installed and working properly, can I just use the actual PS1 disc? (Instead of downloading ROMs)
And lastly, when I open the emulator (epsxe1) why am I unable to maximize it? I just get the main blue screen and it's minimized.
THanks.
darren77
Next LVL Up at : 15
Next LVL Up at : 15
Fav System: NES
Postby SE7EN » Wed Dec 26, 2012 11:59 pm
darren77 wrote:A two part follow-up question: because I haven't tried it yet......if I have the emulator installed and working properly, can I just use the actual PS1 disc? (Instead of downloading ROMs)
THanks.
1. yes, you would just need to use a plugin that supports your cd drive and point it in the right direction
2. the main window will open when you actually start a rom, and that can be fullscreen or maximised.
