Winfellow problem
Winfellow problem
Postby KaLore » Tue Jul 27, 2010 1:33 am
Hi all you Retrofans.
I am running Winfellow V0.4.3 build 1 and trying to get my keyboard to run as one of the demo`s I have requires me to type in the name of the module I want to play.
Can anyone help?
Please!
Many thanks
KaLore
Re: Winfellow problem
Postby Hot Trout » Mon Aug 02, 2010 9:52 pm
Guys, can anyone help this member ?
Postby Guest » Tue Aug 03, 2010 3:50 am
So to clarify, the problem your having deals with your keyboard?
My advice with most others would be to restart your computer to being with. If that doesnt solve it try switching out the keyboard for another or try it on another computer. If all else fails though, there is always the on screen keyboard (assuming your are running windows) that you can bring up via the accessories folder.
If this is not your problem let us know.
*Note* There is also a newer version of WinFellow being 'alpha v0.4.4 build 1'
Postby Jesse » Tue Aug 03, 2010 3:23 pm
I have no idea about Winfellow. I might try it out later to see if I can help.
Jesse
