Project 64 plugins
Project 64 plugins
Postby bub63664 » Tue Jul 24, 2012 2:53 am
Hello, I am having issues with these games in Project 64: Castlevania, Conker's Bad Fur Day, Neon Genesis Evangelion, Quest 64, Star Wars Rogue Squadron, Star Wars Shadows of the Empire, and Super Mario 64. I was wondering if anyone knew which plugins I needed to fix these problems. If anyone can help please respond. Thank you in advance.
bub63664
Fav System: Xbox360
Re: Project 64 plugins
Postby gamfrkI » Tue Jul 24, 2012 3:01 am
i use the following plugins
video : jabo's direct 3d8 (1.7.0.53)
audio : jabo's direct sound (1.7)
controller : jabo's direct input7 (1.7.0.8)
rsp : rsp plugin (1.7.0.2)
so far any game i use has not had any problems with these plugins
Postby bub63664 » Tue Jul 24, 2012 5:03 am
Thank you so much for the advice. I really appreciate it.
bub63664
Fav System: Xbox360
Postby SE7EN » Wed Jul 25, 2012 4:22 pm
you also need to look into the 'notes' tab on the project64 window. some of the games you listed have issues. I am pretty sure Castlevania has some problems, Conkers is supposed to have some problems (although it runs 100% for me) and possibly high system requirements, and Star Wars Rogue Squadron is as far as I know, on a list of a couple of Star Wars games that is unplayable by any current emulator. Mario64 should work though just fine with any default setting.
