Wizardry disk images: what now?
Postby SmokelessJoe » Wed Jun 13, 2012 5:16 pm
I was ecstatic to see the original release of Wizardry - Proving Grounds of the Mad Overlord in the Roms/IBM/PC-5150/Boot-Disks section! Hooray!
I've downloaded and extracted the files, so now I have a couple .IMG files that are small enough to fit on a double-density (360 kB) floppy disk. So far so good.
But now I'm stuck. I'm a total noob and I have no idea what to do with these files now.
Is there IBM PC emulator that can boot from these .IMG files?
Is there any way I could burn these to a floppy disk? I have an old 486 desktop with a 5.25" drive running Windows 3.1, if that helps.
Any help appreciated!
SmokelessJoe
Re: Wizardry disk images: what now?
Postby SmokelessJoe » Wed Jun 13, 2012 8:53 pm
I tried using DOSBox with no luck, but tantalizing results! Here's what happened:
Using the DOSBox command "boot", I can boot from a disk image. This should work great for old games that needed to be booted from a floppy, just like Wizardry. The command is:
boot /path/diskimage
If I try the boot command with the file I got from:
Wizardry - Proving Grounds of the Mad Overlord (198x)(Sir-Tech Software, Inc)[Orginal Release][Master Disk].zip
I get the error "Can't find system disk".
If, however, I try the boot command with the file:
Wizardry - Proving Grounds of the Mad Overlord (198x)(Sir-Tech Software, Inc)[Re-Release][Master Disk].zip
DOSBox boots it just fine and I can play the re-release version of Wizardry. Nice, but I wanted to play the original release.
Both files are from the Roms/IBM/PC-5150/Boot-Disks directory. It looks like it's just the "Original Release" that I can't use with DOSBox.
Any ideas on what to do now? I'd really like to play the Original Release version. Thanks!
SmokelessJoe
Postby te_lanus » Sun Jun 17, 2012 7:00 am
The only Emu I found that could run "Wizardry - Proving Grounds of the Mad Overlord (198x)(Sir-Tech Software, Inc)[Orginal Release][Master Disk]" is MESS, using the Ibm5150 Driver.
Dosbox, PCEM & PCE couldn't run the disks in my test
Postby burntbiscuit_99 » Sun Feb 23, 2014 4:01 pm
How did you get the original Wizardry working with the Mess/IBM5150 combo? I was able to get it going but when I got to the point of playing the game it says I need to make a scenario disk. I started the emulator with the scenario disk mapped to flop2. When I went to the utilities portion to create the scenario disk it asked if I had 1 or 2 drives. I said 2. It then said to insert the master disk in drive 1. It should have been there already because I started the game off that disk and the master disk image was mapped to flop1. I keep pressing return and it doesn't recognize the master disk and I get stuck there.
I've played around with things for a while and still can't figure it out. Any help/guidance would be greatly appreciated - thanks!
burntbiscuit_99
Fav System: IBM PC
Steam ID: None
Postby burntbiscuit_99 » Tue Mar 04, 2014 9:07 pm
Nevermind - the problem was that I shouldn't have mapped the scenario disk to flop2. Instead I just booted off the master disk image in flop1 and then when it asked for the scenario disk I brought up the MESS console to swap the scenario disk into flop1 and made it read/write. From there I was home free and playing Wizardry like I used to on my PCJr!
burntbiscuit_99
Fav System: IBM PC
Steam ID: None
