problem to play *.fdd rom
Postby bambang_314 » Sun Apr 24, 2011 3:58 pm
hello,
i have problem in how to play a game. i have Downloaded game words worth (1993)from elf
ex:
Words Worth (1993)(Elf)(Disk 01 of 12)(Disk A).fdd >> 12 part
Words Worth Special Disk (1993)(Elf)(Disk 1 of 2)(Disk A).fdd >> 2 part
the problem is i don't really know how to play file with that extension (*.fdd). all info i know is that those game initially played for NEC pc-98.
i have try some emulator :
magic engine v1.1.3
nekoproject2
t-98 next
ootake
dosbox
spectaculator
do anyone of you know with what program should i open those file (with step by step).
thank you
bambang_314
Fav System: nintendo
Re: problem to play *.fdd rom
Postby te_lanus » Sun Apr 24, 2011 7:02 pm
Get Anex86 from here: Sorry this link is now dead
Steps to install
  • extract it to it's own folder (ie c:\pc98), and extract the game to it's own folder (ie c:\pc98\disks)
  • in the Anex folder there is a sub-folder (vf011010) go there and click on vfic.exe
  • in the format dropdown list (highlight FDI(anx86) Format)
  • in explorer go to where you've extracted the game, and drag and drop the files one at a time on vfic. it will create two fdi files
Steps to start
  • Open anex86.exe.
  • Goto Config, then click on the tab that says font, then click on the button: (...) it will open a file requester (these two steps need to be done only once)
  • goto the folder where anex86 is extracted, then click on (anex86.bmp) then close the window by pressing the x in the title bar.
  • click on the (...) button alongside the fdd1 dropdown box. goto were you extracted the game, and click on disk 1
  • Do the dame for fdd2. then press start
Postby bambang_314 » Mon Apr 25, 2011 2:44 am
thank you for your response. i will try ASAP
bambang_314
Postby crustyasp46 » Mon Apr 25, 2011 8:18 am
bambang_314 wrote:thank you for your response. i will try ASAP
Let us know if it works for you, thanks.
Postby bambang_314 » Tue Apr 26, 2011 3:01 am
it's work for me. thank a lot.
bambang_314
Postby Hot Trout » Tue Apr 26, 2011 4:24 pm
Glad you got it working.
Nice one te_lanus :clap: :hi:
Postby genesisflare » Thu May 23, 2013 2:17 pm
i do the same but the game says no disk, btw i am now download the emulator from your links
genesisflare
Postby kmjr1989 » Wed Oct 30, 2013 5:16 am
I downloaded the file you that you linked to and it didn't install Anex86 (don't know what it install - nothing that I could tell.) Would you be able to re-upload the installer?
kmjr1989
Postby Hot Trout » Wed Oct 30, 2013 11:13 am
I will get Anex86 added to our own emulators section hope fully today. Please check it again later.
p.s. BUMP this topic if this does not happen.
Postby PMJPlay » Wed Oct 30, 2013 1:10 pm
Done!
