Running older DOS games on new pc
Postby shanefalco » Wed Jul 28, 2010 11:58 pm
i have downloaded say wing commander and would like to run it but after install it doesnt seem to run. Any ideas? Am running windows xp. Thanks for the help.
shanefalco
Re: Running older DOS games on new pc
Postby gamfrkI » Thu Jul 29, 2010 1:37 am
try using dosbox
Postby Hot Trout » Thu Jul 29, 2010 9:41 am
I agree. DOSBox is quite simply the best thing to use to emulate the older dos versions and associated hardware from that time (Soundblaster 2 or PRO). Checkout the new emulators section or also visit PC section of the roms.
Postby shanefalco » Fri Jul 30, 2010 7:56 pm
thanks a lot guys will give it a try
shanefalco
Postby Guest » Sat Jul 31, 2010 4:18 am
For some reason I just have a really hard time with DOSBox. I can do it and all, but it just feels like I have to do waaaay too much to get to my game where other things like a NES rom I just click browse and double click the rom and bam, ready to play
Postby Kherr » Sat Jul 31, 2010 3:16 pm
Guest wrote:For some reason I just have a really hard time with DOSBox. I can do it and all, but it just feels like I have to do waaaay too much to get to my game where other things like a NES rom I just click browse and double click the rom and bam, ready to play
Guest, this is because it's emulating DOS... not a console. DOS was never easy, but it does bring back memories of getting games to run after installing them... frustrating as it was... :D
Postby jhk72 » Wed Aug 04, 2010 6:41 am
how do u use dosbox it is confusing how do you input the rom
jhk72
Postby Hot Trout » Wed Aug 04, 2010 9:15 am
Extract or install the game into a folder (remember where this is and if given the choice, make it somewhere simple like C:\gamename
Run DOSBox and navigate to the folder the game is extracted/installed to.
Type in the name of the .exe or .com or possibly .bat for that game.
Postby gamfrkI » Wed Aug 04, 2010 10:32 pm
Postby arinlares » Sun Aug 15, 2010 8:31 am
An excellent solution I've found for using DOSBox is DBox. It works for Mac, Windows, Linux, and anything else Java runs on. When you install for Windows, it also installs DOSBox, so it's a one-stop download. I tend to not want to futz around with the command line in DosBox, so this is what I use.
arinlares
Been thanked: 5 times
