xbox dead?
xbox dead?
Postby micbanand » Tue Feb 21, 2012 1:17 pm
I have a xbox v 1.1 with a cheapmod chip.
It loads with microsoft logo with xecuter2 instead of microsoft.
then it goes total black. (green circle)
tried to load slayer 2.7 and softmodder deluxe 5.11 nothing happens.
got it for free because of this problem.
problem is i don't now dash, kernel or eeprom.
dont get any error when loading my ndura softmod from my 1.6 goes black screen. before i unlocked the disk I got kode 6 as supposed.
with blank hd i get kode 16 gues it because my cheapmod cant pass clock check.
problem started because he changed name in dash over ftp.
could use some help! :headbang:
:cry: :cry: :cry:
hope my enlish is okay thanks
Post #2:
seems the org tsop is dead.
I'am pretty screwed!
wild guesses are more than welcome.
Post #3:
changed dvd drive with one iam sure working and testet. nothing. goes black screen.
if open drive it show logo an xecuter2. then black.
is it pointing to something very specific?
is there anyway i can reset to default? without ekstern flash??
Post #4:
hmm
gonna make a switch d0-ground on my 1.6
solder a socket in. then hotswap the cheapmod chip.
flash it with evox.
or whats the best flash tool?
whats the best bios? m8, m8+ 5035 or what??? never flashed before
AND if it's not working! you will see pictures of a very bad xbox!
Reason: Please use the EDIT button on your latest post to add information to it, please do not double, triple, and quadruple post as it's against the rules
micbanand
Re: xbox dead?
Postby Kherr » Fri Feb 24, 2012 4:23 am
That sounds pretty cool that you have a modded Xbox at least... I never bothered to mod mine. Show pics of it working if you fix it... otherwise... show pics of it busted up if it's just trash at this point... :3
Users browsing this forum: No registered users and 16 guests
