List of Compatible External Storages for Nintendo 3DS and Wi
Postby RoboCop » Sat Mar 29, 2014 11:32 pm
Compatible USB storage devices
You can expand the amount of available storage space with external USB storage devices.
Nintendo recommends using self-powered hard disk drives, i.e. devices that use an external power supply instead of drawing power through USB. Devices that draw their power from USB ports are known as "bus-powered" devices, and are not recommended for use with Wii U. For the best results with storage devices, we recommend using a hard drive with its own power supply that connects to the Wii U via the USB port on the console.
Please note that you cannot remove/connect a storage device while the power is on.
We have found that the following external storage devices work with Wii U; these devices have been subjected to basic performance tests:
Buffalo HD-LBU3 series
HD-LB1.0TU3-EU
HD-LB2.0TU3-EU
For more details please visit:
http://www.buffalo-technology.com/en/hd-lbu3-drive-station-external-usb-3-0-hard-drive.html
Toshiba STOR.E CANVIO Desktop series
HDWC120EW3J1 (2TB/white model)
HDWC120EK3J1 (2TB/black model)
HDWC110EW3J1 (1TB/white model)
HDWC110EK3J1 (1TB/black model)
http://www.toshiba.eu/storage
In order to use the following USB storage devices, Wii U system software version 2.1.0E or later is required. Please see our System Update section for more information.
Seagate Backup Plus Desktop Drive
STCA1000200 (1 TB)
STCA2000200 (2 TB)
http://www.seagate.com/external-hard-drives/desktop-hard-drives/backup-plus-desk/
Seagate Expansion Desktop
STBV100020 (1 TB)
STBV2000200 (2 TB)
http://www.seagate.com/external-hard-drives/desktop-hard-drives/expansion-hard-drive/
Western Digital (WD)
My Book™
WDBACW0010HBK-EESN (1 TB)
WDBACW0020HBK-EESN (2 TB)
http://www.wdc.com/en/products/products.aspx?id=870
The devices above have been subjected to performance tests. However, please note that we do not guarantee the performance of these devices.
Please consult the instruction manual of the USB storage device for operation information.
Specifications of these devices are subject to change, and there is a possibility that these devices may not function properly with Wii U due to a specification change.
http://www.nintendo.co.uk/Support/Wii-U/Storage/Compatible-USB-storage-devices/Compatible-USB-storage-devices-676063.html
Which SD Card should I use?
The Nintendo 3DS and Nintendo 3DS XL systems work with SD Cards up to 2 GB in memory, and SDHC cards from 4 GB to 32 GB. You can use the SD Card included with your Nintendo 3DS or Nintendo 3DS XL system, or the following Nintendo-authorised SDHC Cards: 8 GB [RVL-037] or 16 GB [RVL-038].
We have also conducted functionality tests on the following SD Cards:
SanDisk Extreme:
4 GB [SDSDX-004G-X46, SDSDRX3-4096]
8 GB [SDSDX-008G-X46, SDSDRX3-8192]
16 GB [SDSDX-016G-X46, SDSDRX3-016G]
32 GB [SDSDX-032G-X46, SDSDRX3-032G]
Panasonic GOLD:
8 GB [RP-SDUB08GAK]
16 GB [RP-SDUB16GAK]
32 GB [RP-SDUB32GAK]
Lexar Premium Series:
8 GB [LSD8GBBBEU200C10]
16 GB [LSD16GBBEU200]
32 GB [LSD32GBBEU200]
(Updated 1/2/2013)
The above SD Cards have been subjected to functionality tests. However, please note that we do not guarantee the performance of these products.
Please consult the instruction manual of the SD Card for information.
Specifications of these SD Cards are subject to change. There is a possibility that these devices may not function properly with the Nintendo 3DS or Nintendo 3DS XL system due to such a specification change.
SanDisk Extreme is a trademark of SanDisk Corporation, registered in the United States and other countries.
http://www.nintendo.co.uk/Support/Nintendo-3DS-XL-/FAQ/Accessories/Which-SD-Card-should-I-use-/Which-SD-Card-should-I-use--719810.html
RoboCop
Been thanked: 47 times
Re: List of Compatible External Storages for Nintendo 3DS an
Postby Dragon Mech » Mon May 12, 2014 1:58 am
very good post RoboCop. :goodpost: :thankyou:
Has thanked: 570 times
Return to Modern Consoles
Users browsing this forum: No registered users and 13 guests
