HOWTO | Jailbreak an iPad, iPhone or iPod Touch
Postby gamfrkI » Tue Aug 24, 2010 2:19 am
requirements:
Any iPad, iPhone, or iPod touch on firmware 3.1.2, 3.1.3, or 3.2 (not 3.2.1)
Any version of iTunes 9 earlier than 9.2
Computer PC or Mac
1.sync your iPad, iPhone, or iPod touch with itunes (the iPad should be running OS 3.2)(this is important dont skip it)
2.download the spirit jailbreak for Windows,Mac OS
3.connect iPad, iPhone, or iPod touch to computer using usb cable
4.run the spirit jailbreak app [you need to be a administrator to run in windows][and if it still doesnt work run it on compatibility mode as windows 98/me]
5.click the jailbreak button
6.the iPad, iPhone, or iPod touch will automatically reboot
7.once rebooted youll see the cydia application installed on your iPad, iPhone, or iPod touch desktop
your iPad, iPhone, or iPod touch is now jailbroken
Re: Jailbreaking a iPad, iPhone or iPod Touch
Postby Guest » Tue Aug 24, 2010 2:21 am
wish it was always that easy
Postby gamfrkI » Tue Aug 24, 2010 2:22 am
it wasnt that easy 4 u :o
Postby Guest » Tue Aug 24, 2010 3:09 am
Im talking about in general. This is usually the process:
1) New device comes out
2) A little bit later (depending) someone says they've cracked it -woot woot-
3) a huge and complicated process is given out to crack your own. if you mess up your screwed
4) [sometimes] A simpler process is delivered to make it easier
5) An automated process that requires an iq over 6 to acomplish is released
6) New product released or a patch
Rinse and repeat
Re: Jailbreak : iPad, iPhone or iPod Touch
Postby JAHGoVeg » Wed Sep 01, 2010 12:49 am
SO TRUE, Guest!!!!!!!!
Re: HOWTO | Jailbreak an iPad, iPhone or iPod Touch
Postby Kherr » Wed Jun 26, 2013 2:13 am
This process is now defunct so I've un-stickied the thread and locked it. Sorry gamfrkI, it is a great tut, just no longer of any use to anyone using any kind of iPod or iPhone or iPad. :hi:
